1 hour ago, Piggaz said:
Apparently 480 AWKW was the most power out of a 8374 awkw (out of an Evo) Scott has seen on his dyno.
Nick (3.0/8374) went 461, 24 psi
Pete (3.2/vcam/8374) went 457awkw, 25 psi tapering back to 21 psi (120,000 turbine speed).
I don't know. It's all dictated by that magic 127,000 RPM turbine speed. What will be more interesting will be the boost level that it'll need to get there. Going off the -5 setup, it went 441 at 19 psi. Realistically, I should have just left it there.  Boost level I'm gonna peg at no more then 25 psi, tapering back down.
How does that power compare with Garrets and Precision etc on same dyno? Sounds lower than I would expect but apples with apples
I'd have to ask Scott, Simon. Haven't really asked to be honest. Pete did a back to back between a 6266/0.84 to a 8374/1.05 but the car was pretty ill when it arrived. Having driven that car in both setups, the 8374 belts it for the stuff you can't see on the dyno. Your assume the 6266 with its 0.84 ass end would be stronger down low, that is most definately not the case, let alone the transient stuff.
If his car was anything to go off, the PTE needed 28 psi to make 460 kw and the EFR needed 21 psi to make 457. *Different dynos though.
A 9180 blows about 550 kw on that dyno for example before it taps out due to speed.
A Gen 2 3582R, PTE 6266 and a 8374 comparison would be awesome. But the fab work involved makes it a very expensive exercise.
Honestly I'd have given a EFR8374 a go if it wasn't for all the fab... Instead I seem to be stuck with the 6262 (not being a bad thing) but now I'm up to 5 sets of cams that have been in the car haha
Latest better be awesome considering I've gone backwards 4 times in some way shape or form
5 sets of cam setups? What are you chasing to warrant 5 different setups? You could have had a EFR setup with change.
I really hope mine spins more than 550, be a fair bit off where I want to be.
That speed "cap" is a pain.
Owell only one way to find out ?
7 minutes ago, fatz said:
What happens when you pop a ic pipe at 25psi and over speed them?
Boom?
I doubt the boom is that inevitable, I'm fairly sure a mate had that exact thing happen on his EFR8374 drift car after he first went to one and he just lost power and his heart sunk because of the stories about overspeeding - but then realised what happened, got it sorted and carried on.  Car is still going strong.
Worth avoiding, obviously - but not necessarily immediate death.  Much the same as how you have people running around with boost leaks all over the place with stock ceramic turbo Nissans who never realised it.  I guess not having the full load on the turbo MAY take some of the edge off?
Edited by Lithium
2 minutes ago, Lithium said:
Lol!
How is your car going?
Slowly. Motor is almost there I am told then its off for fab work before wiring and then tune.
Maybe July...
1 minute ago, Lithium said:
You staying with the EFR party?
I've gone a 6870 1.15 rear for now as I wanted over 600awkw. It looks like the 9280 will do the power I want when it is released so I plan on swapping back at that point.
I just wanna go fast
  • Like 3
Boom?
I spose sensor back to ecu, if it falls out of "x" parameters then have some sort of protection in place... whatever that may be.
What am I missing with these EFRs?
I thought you just took a look at the comp map, aimed for a decent efficiency island for your power goal, as you do with any turbo choice, and that was that?
Can't think of when I've seen people talking about turbine speed so intently with other brands. Are the EFRs particularly sensitive to overspeeding?
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast and very unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If I lie about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley has terrible reviews but @Duncan made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
