6 minutes ago, ActionDan said:
What am I missing with these EFRs?
I thought you just took a look at the comp map, aimed for a decent efficiency island for your power goal, as you do with any turbo choice, and that was that?
Can't think of when I've seen people talking about turbine speed so intently with other brands. Are the EFRs particularly sensitive to overspeeding?
It's got to do with the turbine wheel. Because of the light weight wheel, the downside is that it has a maximum RPM that it doesn't like going over. It's not exactly a secret.
There have been a few failures, but not THAT common.  A lot of the earlier EFR failures which are documented were actually more to do with the early build issues than actual overspeeding
Worth noting that the tuner at Insight who tuned that Tilton Evo (won WTAC 3 times on the trot) has never blown an EFR up, ever.
Sensors run, turbos spun to their limit.
On 4/25/2017 at 2:33 PM, SimonR32 said:
Honestly I'd have given a EFR8374 a go if it wasn't for all the fab... Instead I seem to be stuck with the 6262 (not being a bad thing) but now I'm up to 5 sets of cams that have been in the car haha
Latest better be awesome considering I've gone backwards 4 times in some way shape or form
I assume you are chasing some response gain?
Props to you for actually trying 5 different combinations.....
4 hours ago, ActionDan said:
Post some f**king numbers >.<
My car is delayed so I need something.
I see the dyno thread got a bump at least.
If you want to see numbers just go to the precision thread :4_joy:
Yeah but if you had a plug in Halaltech it would already be tuned.
  • Like 1
On 25/04/2017 at 3:44 PM, Piggaz said:
5 sets of cam setups? What are you chasing to warrant 5 different setups? You could have had a EFR setup with change.
First motor had Grex cams from Japan but dropped a valve guide so I purchased some Tomei Type-R poncams for the new motor... Installed but turns out it already had Type-B poncams. The Type-R's didn't really want to make enough power so I chucked the Type-B's in to see how they went. They were average at best still not making all the top end power and a fair wack laggier. Needed to do head gasket so we did the head (with minor porting), guides etc and chucked in some wiz bang Kelford split duration 274 jobs. They made good power (most it's ever made and maxed out the turbo) plus plenty more grunt on lower boost settings but lacked a fair bit below 4500rpm, especially on road/track. So went back to Kelford and had signifcant discussions and planning via email to come up with a new custom grind. They are in the hole now and just need a tune, fingers crossed they are good otherwise I'm going to try find the old Grex and buy them back haha
So in terms of cash, once I sell the Kelford split cams to someone with a bigger turbo or stroker I should be less than $1000 out of pocket for all the testing.
Basically I want my cake and eat it, turns out the Grex cams were probably almost there, now the never ending search to get it back to where it was or a little better :)
  • Like 1
260 poncam strikes again ?.
What sort of grind did you decide on with Kelford? Lift at 50 thou (or 1 mm) and lift? Can understand if you don't want to release that info though ?.
Considered pulling the head off to relieve it and run more lift with a not so long duration?
Are you suggesting those idiots on the forum were right and that increasing duration decreases bottom end torque and makes a turbo come on later? And anyone who bought bigger cams to improve response has actually done the wrong thing?
Wasn't that pretty much unanimous?   Well the first part was, the second part would be a little bit of a blurred line.
  I can't remember the specifics of the thread but the Kelfords were an interesting cam and there was hope they'd be pretty cool and to be fair- without checking the thread I'd have hoped the compromise wouldn't be as bad as it sounds it was, but my argument is that the overbearing "any longer duration is bad, fullstop" is a bit misplaced, the trick is finding a match between the rest of your setup and how you use it.
It's a shame they haven't worked as well as you'd hoped, I actually had some hope for them - would have liked to have seen them "happy" by 4500rpm, especially how Kelford marketed them.
Edited by Lithium
Unfortunately it's not unanimous because to many people still the the rb26 works different to every other combustion engine and believe fitting bigger cams will improve bottom end
apart from that there was a lot a sarcasm in my post
3 minutes ago, r32-25t said:
Sarcasm is lost on you isn't it?
No, not at all.  I am one of the people you appear to be mocking as I feel that the blanket "shorter duration is better" statement glosses over things too much.
Edited by Lithium
Good luck Simon. I've got Kelford L182-A baby cams going in now, all indicators point to them being a better option than the Tomei stuff. My goal is to maintain similar response while allowing the motor to breath up top. Happy to dial the gears for response at the expense of the top end as a compromise. I had a really good chat with Josh about my setup/goals and realistic expectations and we settled on those cams with the intent of me creeping over 500rwhp on -9s if possible.
He also advised me to go the BC springs given the price I got them for rather than trying to insist I buy his springs, which had lower seat pressure.
Very good to deal with, especially when it turned out the Cams the seller gave me were 32/33 CAS lol He modified the exhaust Cam keyway in a day and express posted it back to me, customer service is excellent.
  • Like 2
    • It can't be some stupidly proprietary video signal coming out of it that only Nissan's can understand. Surely you can just find some generic camera to stuff in there and use hot melt glue/blu-tac/gaffer tape to hold it in place if need be?
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
