I know there was a situation that made it difficult to start your work , I know you do not like to rush work, I understand that you are a patient man, I am sure you do not want to be a pest to the builder, you are also happy to be able to put some more $s together and these are all qualities I would love to posses , but my background of having work done on  my car has killed all of your fine qualities :(
SO
Any update for everyone :91_thumbsup:
Ya'll African Americans honestly think he would "forget" to update the thread if there was a noteworthy update?
I hope he sits on the final figure for ages and just posts a teaser vid of him driving it out of the shop or something.
Having tuners/mechanics work on my cars has been an eye opener for me, I am much more patient now.
I paid an invoice for some work done two Fridays ago. Does that count? ?
The sensor wiring loom was completed. Hardly worth making a fuss over.
The guy that's looking after it works 3 days a week. So it's getting 3 days a week of work done on it. I would say by the end of this week all wiring (box, MAC valves, ecu, fuel system and sensors) will be done. Then it's just tuning.
Atleast it's been started. ☺️
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
