Area under the curve is more important than top end power IMO, your car will be mental. That's why i designed my car the way i did.
Even at my relative power level i find for street work, it's getting to the point the extra power is useless.
I'm loving my current tune on 98, i can't wait to see it on E85 again.
4 hours ago, Piggaz said:
I believe Scott is spending all day on it today. No idea where it's all upto apart from the information I've posted.
Cant see it making anymore than 480 awkw. That's as much as Scott has seen out of a 8374.
how hard are you planning on pushing it - boost wise?
Whatever 125,000 Rpm is. It will be higher early on then taper off as the engine consumes more air.
So. Bring on 125 k ASAP and leave it there. Boost, who cares but at guesstimate, 30 ish psi as it comes on (late 3000's/4000 ish) and mid 20's at 8000 rpm. With any luck, hopefully less "boost".
interesting. looking forward to it.
Just for fun rather than anything else - i compared my power in the midrange compared to yours - i'm at ~100kw at 3700 - you've got ~270kw - same turbo lol
I need me a stroker kit
just get V-Cam OR Nitrous. OR both?
2 minutes ago, SimonR32 said:
Has the fluff fallen out of Ernie yet? Otherwise not a real EFR :4_joy:
Lol. When are you going to man up and buy one. Piss off that nug PTE ?
Update time!!!!
Fuel is E56 only
Still not bringing it on as hard as possible, just letting it come up as normal (not tuning via turbine speed YET).
Turbo is a EFR 8374/1.05 AR turbine housing.
300 KW at 4000 ish, 461.5 KW at 6000 RPM then it falls over. I didn't see this coming but the issue is the turbine housing is too small! The next size up is a 1.45 AR which is the same housings they used on the indy cars. They were saying that the head is  just breathing like a weapon. Funnily enough, both Petes and Intune's car were able to stretch to 8000 RPM even though their engines are larger!
For the time being I will take it back and enjoy it for a while. If I put the 1.45 on, Scott thinks it will see 500 KW and make even more through the middle by 20-30 KW. However, i'll lose a tad at 3000 ish RPM.
I suppose I better get used to short shifting. Lucky I have 6 gears.
For those of you who are hooked up on boost numbers, 25 psi at 3850 ish RPM but that will improve again. Pretty sporty for a lazy, laggy single turbo :1_grinning:
  • Like 9
1 hour ago, Piggaz said:
Update time!!!!
Fuel is E56 only
The tad you loose at 3000, can I have it please :wub:
49 minutes ago, Piggaz said:
Go put a 6258 on your car.
I built mine so I could have a strong top end . I want to keep it and as tried to get it as good as I could down low .
I don't want to loose anything from the top end, I still can rev it to 8000 if I want .  Just like it a bit different than most I guess :/
That head you had done is something else , cannot wait to see it all working together, what a machine :wub:
Congrats Paul, now enjoy it for awhile and mull on can of worms thats just been opened but was hiding there in front of you.
What brake set up are you running ? Reason I ask you may find that other things may need upgrade first, like stopping ,fine tune the nadling (think you sorted that but f**k me too much alcohol brain damage cant remember shit) then sort last power upgrade, all just subtle stuff. Then you'll have the ultimate skyline weapon.
Brakes are sorted, mate. 365 mm 6 pot fronts/350 mm 4 pot rear alcons. Need to change the front pads, the ones in there are woody nuggets!
Suspension and arms are all sorted, although it needs a wheel alignment. The whole rear end has been out to replace the sub frame bushes.
Cant believe I'm out of rear housing. Quite strange that the 3.2 and 3.0 can go to 8000 rpm but the little 2.8 cant. I suppose those polished ports ain't so bad after all ;).
I have in my head the 1.45 isn't a straight bolt on. The housing absolutely MASSIVE!!!! Adrian (bloke from Insight) said if they made a 1.6 you'd put it on haha.
Data is showing 46 Psi in the exhaust manifold.
Im heading out tomorrow to sit down with Scott. Grab as much data as I can.
  • Like 2
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 12 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
    • Take this with a pinch of salt, it's from someone (me) who got annoyed with turbos entirely. I hated aftermarket lines. If I had the option to use hardlines with whatever turbo I had - I would use them, 10/10, 100% of the time. The only reason people go larger, heat resistent, shielded lines etc is because they have to. And yes they don't last forever. Even if you spend big bucks on all the best heat shielding money can buy, with the best heat resistant, fuel resistant, oil resistant, radiation resistant hose, they get stiff and break down and just don't last the way a metal pipe will.
    • Unfortunately I am quite literally halfway across the globe. So all sources for parts like that are far away for me. What do you mean by that exactly?
