I think a lot of people throw parts in without testing or understanding what the bottlenecks are so you might find that a good turbo/head combo is worth more than displacement as the bottle neck is the head flow at this power.
Not saying capacity won't help, but might not show its true potential til later in the power game.
Tao was schooling me on the CA as I had some ideas and he basically told me flat, do nothing else until you put cams in it as that's what stops them breathing beyond what a T28 is capable of.
Pays to listen to experts, sometimes.
Fantastic result dude :D
Pauls head is something else :)  I do mean the one on his 33 not your normal head job , can't wait for the final tune next week :521_rocket:
goes to show most forum warriors have no idea what theyre talking about....f**k twins & f**k not polishing the ports.
NAPREC know what theyre doing when it comes to getting big numbers out of heads
my NAPREC prepped SR head has tolerances to within 1 thou....fkn precise. my engine builder said its some of the best machining he has ever come across....and he's built plenty of 1000hp+ drag motors.
Well to be fair precision is literally in the name
Piggaz give us a run down on the engine again? Cheers
GT block
NAPREC head (1.5 mm OS valves, intake squish pad removed). HKS did the porting.
Tomei 2.8 stroker (9.0:1 comp), 0.9 mm head gasket, 28 thou squish clearence.
Nismo intake plenum
6 boost exhaust manifold, 38 mm gates, 8374/1.05 snail. 4 inch exhaust with SMB mufflers
Emtron KV8 ECU. Bosch 1700 cc injectors.
Hypertune intercooler. 680 x 325 x 100.
At 4000 RPM the -5's were at 220 rwkw. The 8374 makes 300 awkw.
  • Like 5
I'll be back when you stop f**king around with that baby turbo and get a 9180 on there, or even maybe a 9174 if you want to be soft  :9_innocent:
300rwkw at 4000rpm is about double (plus some) power that time makes so it's not exactly like you need that much grunt that low :)
A 9174 would just make the EGP pressure issue worse and in my mind it seems like a bit of a GT RS shit going on. Not that it's horrendously bad (It wouldn't be no twin buttplug pressures), That's NOT a fix. Maybe beccause it's actually being monitored and having all the data there it becomes " an issue". Not just being ignorant and "she'll be right" Being realistic, a 460-500 KW GTR is no slouch. Much more and you start going down the driveline busting bullshit again. The whole idea of this was to make it more reliable and have the engine happier. If you want to fund a 9180, I wont say no :6_smile:
I just drove it and to describe it in one word, DUMB!
It makes an absolute mockery of the -5's...there is NO downside. Breathe on the throttle and it's just soooooo zingy. Between gears (I was still clutching in between shifts as it was sensory overload) there is NO lag. "Twins for response"... pfft. It's all the stuff that a WOT dyno run doesn't show thats the standout. It's ready to go at almost any RPM. So lively and peppy!
The plan is to run it up tomorrow on E85 and see what it spits out. Scott did say depending on what it's doing, he may sacrifice a bit of top end and taper the boost back up high to extend the power band. Scott is going to SEMA so if he can grab a 1.45 AR rear housing we will put that on and advance the intake came to bump up the low end. Can't advance the intake at the moment (still set to 0/0) as even now Scott is holding the turbo back down low. Really, even if I lost a tad it wouldn't be a great deal anyway.
Exhaust is nice and quiet, even when up it.
Going by the temps we are seeing before and after the compressor, its more than happy and have some left up our sleeve. Turbine speed will be wired in tomorrow (were waiting for a plug).
Gearbox is still pissing out oil!!!!! I need to make a catch can that drains back to the filler plug. Frustration level's 10/10!
I forgot how cranky the bloody diff was when cold! It needs a wheel alignment before I get it back, it's all over the shop!
I rolled it on in 3rd and no problem having the wheels chirp in a straight line.
Driving a sequential without a gear display is bloody interesting also. The display powers up but because we have changed the gear position sensor it no longer reads. Will fix!
  • Like 10
*Yawn*
Is this ~still~ going on?     EFR Turbos are so last year you know...   ;)
(good to see you finally pull your finger out geesus, the car must need new air in the tyres by now....)
  • Like 2
this build is the real f**king deal.... no half ass shortcuts taken here
true RB gunner.....built with the best fruit on the market......
enjoy the ride brother
im sure this will leave the 80s F1 SKOLA tune in the dust HAHA
  • Haha 1
Well he hasn't posted a result for a reason ?
  • Like 1
  • Haha 1
29 minutes ago, Aggroman said:
jeez paulie its been so long do you even remember how to drive? :P
Not really. The Lancer on a cold night was starting to get exciting!! Now it's warming up, the AC is back on. It's a nug now :(.
2 minutes ago, Piggaz said:
You got a date?
Yeah , 26/9/17;  E85 tune and THE END !
ish
Well there is the Vcam  to cram in there and maybe a 1.45 , oh a 9180 could fit  in there somewhere and ???
Just go to Insight pick up the car after work tomorrow , get all the information and post it  :)
2 hours ago, Piggaz said:
Not about mine.
Yours!
Pick up for mine is sometime this week. Needs a wheel alignment before it goes anywhere!
bring it out and we can compare how good a 8374 can really be with a solid motor.
am really keen to feel the difference
I tend to find people are a lot more willing to discuss their results and testing in PM.
Easy to think that might be an ego thing but from what I see around here I'd say it's mostly about minimising the drama they have to deal with.
I'm voting yes for thread equality...
  • Like 1
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
