14 minutes ago, Piggaz said:
Well, guys get all excited about a billet wheel being lighter.... but most of the weight is in the turbine wheel. The efr wheel is half the weight of a normal inconel wheel.
Removal of all the small piping and super tight bends of the intake and exhaust. Just look at it all, it's hardly designed for MASS airflow. Put a pressure sensor on the intake of a 450 kw gtr and I bet it's pulling bulk vacuum. Dyson would be impressed.
Haha, Piglets rebuild of his busted Dyson :D
34 minutes ago, ActionDan said:
I wonder why BMW went with all the hassle of twins on a straight 6 motor instead of a slightly larger single?
I guess they wanted to make it laggier. I mean, 1400 rpm is pretty shit response - A single would be on idle for sure.
I bet a cheeseburger that their packaging is not a spitting image of the RB26 configuration.  A huge amount of my argument against low mount twins in a GTR when any kind of flow is needed has to do with the packaging.
Edited by Lithium
Yep 100% you can't get a bigger exhaust housing on to those stock manifolds and the rear intake in rubbish.
Would like to see some low mounted EFR's on customer manifolds.
"When any kind of flow is needed" means different things to different people.
I think you guys need to go back and read some of your own posts from 10yrs ago on here and see how you were reacting to 300-350rwkw back in the day.
For those power levels, even today, twins are fine for a mildly driven street car. Does that mean there are not better solutions? Of course not, it's been a decade of tech advancement, but the argument seems to boil down to "did you know that if you spend more time and money you will get a better result?!".
No shit lol
Edited by ActionDan
  • Like 1
Artec do a 0.85 T28 ass.
4 hours ago, Lithium said:
9180 would do for now :D
Hows that build of yours going?
Sick f**king work Piggy, looking forward to seeing the final result - but you're already smashing it. Can't wait for the data, and for you to finally be able to get out there and do awesome shit with it.  I remember the OTP discussion we had back in 2013 where you were challenging me to think of any RB setup with response and power like your own, bet you wouldn't have expected your own car to end up with a single turbo on the exact same engine and as a result stand up harder earlier than it ever did before? :D
f**king kudos to having the Insight involved to get a great thing even better.
Honorary mention gotta go to the drunken conversations with the Wild the sphincter of the universe Rare Breed.
* This post sponsored by the SAU language filter
Slowly getting there. Wiring was completed last week so a little more fab then it can get some fluids and a tune :)
  • Like 1
I'm curious what spark plug gaps you are running with the Godzilla motorsport kit?
I might need new coilpacks and was thinking this kit over the conventional splitfires.
In the search your the only guy i saw that runs the Godzilla R35 billet coil pack kit, so curious on your opinion on why you went these over spitfires.
I'll have to get back to you on that. Some plug that Scott uses. It's a heat range 9 with a funny tip. I thought I took a photo but I can't find it.
Actually i just saw this in a comments Facebook section of the Godzilla Motorsport page which to me was interesting.
So i spose its just for cars to run high power reliably without a breakdown in spark. Rather than what i thought of larger gap better bang/performance
Bruce Sullivan What plug gap can you run with these ? Can you get away with 1.1 for around the 450AWKW's ?
Cheers
LikeShow more reactions
  Reply  May 28, 2016 at 7:43pm
Remove
Godzilla Motorsport
Godzilla Motorsport No turbo engine should ever run 1.1mm gap . That is only for na engines
  Reply  May 30, 2016 at 5:52pm
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 馃槢
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
