5 hours ago, ActionDan said:
I've seen plenty of videos, results look pretty bloody good to me!
Maybe he just got sick of some of the carry on that goes on in build threads?
Given how some people behave around here these days, there's much less of an incentive to share all the ups and downs of a build.
 I got jumped on from the getgo because I wanted response , said cannot be done ,  go buy a V8 . I got a pretty good result and not a word from the stirrers , LOL
Pauls car is great , plenty of power with good response , win win
PPG honestly is good enough to daily, it's easy to use doesn't crunch when you use clutch and is relatively quiet.
When mine went in I drove it to and from work in peak hour for a week and didn't get frustrated at all, my rear diff is generally louder
On 8/6/2018 at 10:28 AM, Piggaz said:
In the garage on the trickle charger. ?
Drive it every couple of weeks and just getting used to the box. Low speed, low rpm shifting without the clutch without making it go BANG/CRASH. Getting there ?.
Wont be touching it again for a very long time. The level of “over it” is very high.
With the 1.45 housing it went 517 AWKW, up from 486. Turbine speed remained the same at 122,000 RPM.
That is a healthy gain, was there much difference in response
2-300 RPM I reckon. Totally unsure which one I like to be honest. The 1.05 was “so right”. More Kms needed.
  • Haha 1
2-300 rpm seems like a reasonable enough trade off for an extra 30kw
I guess it comes down to what the car gets used for though
  • 10 months later...
Update.
Bought some new wheels...CE28N SL’s in 18x 10.5+22 wearing 295/30x18 AD08R’s. Might put them on in the next 3 months then push it back in the garage and whack it back on the trickle charger. ?
  • Like 4
7 hours ago, ActionDan said:
No roll racing videos, power cruise, drags, circuit, traffic light racing, hard parking, nothing...
This thread does not deliver.
You need to Youtoob better
The truth is out there.
Well, a hill climb somewhere is anyway
But, in saying that, all the good uns should get out and give me pleasure to my eyes and ears.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
