Well its a carbon copy of Elrodeo666's head which was good enough for 445 kw at 1.4 bar on -5's.
Have a look at the inlet ports on Brad's engine (SHOWOFFR32)... that is what they should look like.
BRB. I'll go tell the bloke that ported the HKS drag car that he did it wrong.
Go ahead... All I am suggesting is that the port looks polished from the photo.
To enhance mixture quality it is better to have a textured inlet port surface, especially considering you have massive injectors that wont atomise very well.
Well they proberbly are. But considering the guy has built mild to wild RB's day in and day out for the last 20 years, there must be a reason why he has done what he has done. Who know's what that reason is. I'll ask him in two weeks time when Marcus will sit him down and call me from Japan.
The guy in Japan who has done all the port/polish and r&d on the head has built more high powered full race engines, 9 sec drag engines and drift spec engines then most porn stars have ever had roots.
And yes its polished as well. Why..you'll need to ask him about it but as one of Japans top engine builders who has built 100's of high spec engines, I think he has a resonable idea of what he's doing.
But hey everyone has their opinions.
And Paul its 445kw @ 1.3bar
Just to be clear, your talking flow from a polished port vs fuel atomisation from a rough cut port right?
I figure the rate that Paul's car drinks E85 it probably won't make a lot of difference when its on song. Its not as though there are a lot of injector options to provide a streetable 2lt/min injector flow. The value of optimising fuel atomisation from porting/polishing methods could probably be weighed against the options available for injector spray patterns for similar effect.
Theres more going on with this head than just a port /polish job.
Been all machined up at Naprec to HKS race specs and then some custom work by HKS.
It has been designed purely for response and slamming his arse hard back in the seat and fro getting around a track nice and quick.
Pauls head has a bit more done to it than mine and has been built to handle 600~650kw if he ever chooses to go down that path.
Anyway this is Pauls build so wait a few weeks and he'll let you see whats what and at the end of the day it all comes down to what it does when it's all bolted together and tuned properly.
It will be interesting to see how it all ends up..
Hopefully one day maybe a V-cam and those new turb's that Gav has, it would be quite an animal.
Unfortunate about the old engine!
But it will certainly be interesting to see how this new setup performs in relation to the old setup. Especially with the addition of the new head. What sort of port job was done to the old head?
My mates car runs low 9's with a near std head, ports are just cleaned up. Makes about 880rwhp. What bigmikespec has said holds true, port finish 101 regardless of head type or setup usually doesn't go any finer finish then 80grit. Polishing the surface slows air speed and ruins mixture motion through the port. But maybe this particular guy has a formula that works for him and it goes against the theory that everybody else in the world works around. It will be interesting to see if it makes a difference or not.
Gotta keep an open mind about everything!
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
    • I would suggest equally difficult to find, perhaps edging to the SR. Turkey has almost exclusively Euro market cars, some Korean, few Japanese other than pedestrian shite. I guess they're probably losing the fight against Chinese shit like we are now too. I would vote for a BMW V8, found in a 540i in a wrecking yard somewhere in Deutschland (or possibly Albania).
    • A CigWeld EasyWeld 130 can be had from ebay for $360 delivered. Good for 0.6 to 6mm, which would be fine for my requirements. I guess that on top of that you would need to buy a regulator, hoses and wire. I already have gloves and an auto-darkening mask. How is the gas bottle charged? Do you rent it then pay for top ups?
    • RB20 being an option from factory would mean no custom parts or fabrication required, just have to collect the right bits. Probably would be the easiest option I reckon for a motor swap. How common are SR20s vs RBs in Turkey?
