Just got home from Harris and bit of progress today.
Cams are in without the need for a tunnel bore. Thank god. After 6 hours of messing around with caps the cams turn like a mofo. More work done to the accept an even larger cam if we decide to play around in the future. Relieved for upto 11.5 mm using a 32 mm base circle.
Crank got balanced which was something that Mik didn't do back in 2005 when it first went together. The pictures show how far it was out from Tomei.
Block about to accept it's insides.
Girdle just chilling.
Tomorrow when my main studs arrive it will be dummied up. Might have to take a bee's dick off the top of the block to get to 9.0:1.
not a wieght thats negligible anyway. I had a set of spool rods and a set of custom CP's and rings all wiegh up to within 0.1 of a gram. The manufacturing tech used these days is heaps better than days of old. Well, unless you are buying 1900 dollar stroker kits for 308's :( Im building one at the moment and its giving me a headache! Told the guy what to buy, he seen the el'cheapo kit and thought it'd be the same as a set of carillo's, KB pistons and a Billet crank for less than half the price lol.
A very well known engine builder was telling me about the tomei kits he has worked with and they have always required some 'tinkering' to get them right on terms of balancing and tolerance setting. No big deal IMO, as long as your engine builder can recognise this need.
HUUUGE update.
Everything is bolted up, torqued down. Thats it, it's all done!
Nitty gritty details of the engine are as follows;
Piston to bore clearence is 2 thou
6 thou deck height with a 35 thou thick (0.9mm) gives a squish of 29 thou (Bobby. A bit tighter than what you said but its close enough)
Comp ratio is smack on 9.0:1
CC of the head is 66 CC
Piston CC is - 12.2 CC
Top ring gap is: 16 thou
Second ring gap is: 18 thou
Mains clearance is: 2.1 thou
Big ends is: 1.88 thou
That little prick the bolt fairy has moved some bolts and nuts!!! :domokun: . Sump to bolt nuts and bolts, oil pump, water pump bolts are MIA! Ordered them all from Nissan on Wednesday and luckily most are in the country. Pick up on Monday morning.
  • Like 1
Also picked up my Nismo intake plenum, AFM delete pipes and my surge tank today. I had them sprayed black because I wanted it to took "stock". Well that sorta changed with the single idea :whistling: .
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
