Ok, todays effort. Sammich plate in. We got the box off and back on only for that ring thing in the clutch come off. Box off, fix and back on.
Next issue. TOP STARTER MOTOR BOLT! ARGHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH! Some idiot decided to cable tie the new water line from the rear of the head in the worst position ever. After a few hours (and some brain juice), it's in.
Let's see how we go tomorrow night!
i actually take the alternator tensioner bracket off, flip down the alternator and use a socket and extension and go through the front now. Takes about 15 minutes longer but i loose alot less blood
How many extra bloody lines do you need!?!
I just spent some time this arvo ripping all the crap off the intake side of my 26. So much (crap) stuff...
Be nice if it was less packed!
deleted heat exchanger (because it was contaminated with oil pump gears haha) and HKS put in a fitting from the back of the head for water to go to the top radiator hose housing. That's the prick that caused us issues
any progress ? or just waiting for dyno time
won't be long now. The car is at Unigroup at three moment. A few things to do and onto the rollers. With any luck by weeks end (Can only hope).
Any suggestions for oil type and brand to use for the run in?
  • Like 1
Few things to do my ass.
Lol. I was at unigroup and saw what you brought there!!!!
PS: your front cam cover looks great!! :D
    • Holy smokes brother. If you get there before me, let me know if that was manageable with a hone. I still haven't done anything with mine and probably won't until I get the car MOT'd later this year so that I have another 2 years to do what ever needs to be done. I am at 86.5 now so at least I have the 0.5mm to go up from where I am, but that means new pistons at the very least. Honestly, might consider a stroker at that point.  Cheers
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
