Plus another 200 CC Mark :P.
Was out there again today. Another few little things crossed off the list. Boys have been snowed under. Yavuz reckons fire up Tuesday or Wednesday. Wahoo!
You've got 12 days left!
This is true.
On a side note, I dont think I will have time (read:UNIGROUP) to hook up launch control, so all the cheater AWD vehicles may have a slight advantage at the NATS.
Im drunk, punch me in the face, I deserve it...................
Horse power is how hard you hit the wall. Torque is how far you drag it behind you.
This is true.
I reckon you'd be hard pressed to get that done. You got tyres sorted? When you going E85 farken?
Tyres = M/T Street Radials
E85= When Caltex (or any other supplier) have it in every servo, like they said they would in 2010 :verymad:
Sensor mate. This issue no longer exists. It's getting there. You have the powah with the Link ;).
Ive been a bit scared off with the sensor, Ive heard (google farkin) there has been a bad batch of them giving iffy readings, Ill give it 12 months and if it seems that the issues are sorted then Ill go in balls and all.
All I need is the sensor thingie, injectors, fuel pumps, lines and tune, and around 3-4k of loose change.
And I still need to get the Link tuned for PSI Vs road speed, gotta love the Link.
Went out today and lent a little hand. Brakes are bled, all belts are on and intake piping on the passenger side is on. Exhaust is on, fuel system changes are almost complete (I've moved the ethanol sensor into the boot so it's not in the engine bay).
Almost complete bay.
It's voluptuous behind with the "standard" exhaust.
Well mine's on the road :D
Put 270km on it, running it in.
Tune is next.
You're a machine!!!!
My start up is today with anyluck. Check for leaks, timing and onto the rollers. :D
That's three white GTRs I know of racing to get back on the road!!!
Looking good paul
Mine fired up in the garage last night. Bleed the 4wd, change of rims and few vac line tidies and I'm ready for a tune. Paul, get your beast out of Unigroup so they can tune mine! :domokun::nyaanyaa:
Haha I'm trying!!! I'll hopefully be doing skidz this arvo. Did you drive it Eric? Any idea what your goals are? Where are you gonna limit boost? 260 poncams?
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
    • Duncan:- it affect both sides.  Driver side is worse.
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
