Its a strange one Marcus. On the dyno it's at the same rpm every time (7000). It's not a hard cut or a "rpm cut", but a faint miss. The best way to describe it would be three softest rev limiter ever.
In the road however, depending on how cool it is, it may happen earlier. Gtr Sean drove it before we left for the nats and it missed at 5800. Stupid car.
Make sure you get Yavus to check the settings for ignition/dwell etc. It's the only thing (computer) that has been changed....
I was there today. Tried that one too. :(
Didn't you just replace the alternator? Could the new one be playing up?
Not a chance of that ! 20 mins before it came off my car and it was pumping at full power output. She is almost brand new unit and designed for high power GTR's.
It should be boosting electrical output.
Chuck it on Paul and recheck all your earthing.
CDI time !
Naw wouldn't go that route either. I have a 500R on my 'mini-me' version of Paul's and mine has break-down once it's hot. Hard to nail this one down. Just not sure how to get a hotter spark with lots of amps to make it fire reliably.
Was good to see you lay a decent time there Paul. I'm spewing a bit cause I had to drop out of play so soon. Might have been able to give you at least a little run on times.
Is that not more likely coils then? What coils were you driving with the 500r?
Yeah, your issue is a strange one considering you have tried another set of coils and it didn't change anything :(
I reckon the issue might be the ecu, specifically the fact you're running wasted spark... it'll be over working you ignition system IMO
Thing is, it was perfectly fine 9 months ago. It's pretty much a standard setup bar the igniter which has been modified. Joey has three exact same setup and no issues.
Hi paul
How does the car feel with the higher comp and tight squish ?
Feels really grunty. No need to rev it. I would have liked more comp but without custom pistons it wasnt going to happen.
It will be a few weeks before the tune is finished.
paul,
have you whacked another set of working coil packs or an igniter on the car to test yet?
Yep with coils that just did 425 rwkw a few hours before. Changed ignitor box off the same car. Changed plugs. Then I yelled at it!
Fancy trigger wheel all in check?
Doesnt seem to be any issues there man. Nothing on the logs.
I'm sure it's something silly thats been overlooked due to a serious lack of time.
    • Anyone want to make me an offer to take my v36/g37 3.7l manual coupe in full? Off memory it was low 100k km but the battery is flat so can't tell right now. What's wrong. I had engine problem's that led to a nice clunk. It made it home but it wasn't pretty for the last few kms. Happened under revs. Sounds like bottom end.. never got around to fully checking or fixing it so the car has sat still and unregistered for a few years. Minor bump in front end set the pedestrian protection under bonnet airbag off and that was meant to be repaired, but while waiting for the repair (parts to come) I got the engine problem. The rest of the car is in decent condition. All drive line is good. All interior is good. Leather interior. Wheels in good condition and decent tyres although the ps4s are likely a little too old now it's sat still. Colour of the car is pewter off memory, the dark grey colour. In Camden NSW. Would need a tray back pickup.
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
