Keen to see the dyno results on this Piggaz ..
I am too! HURRY UP FARKEN!!!!
Just ordered at Nismo GT PRO diff centre to go into the rear. It was either that or a Quaife. That'll stop the single peggers which have started since putting the front Quaife unit in!!!
Rightio. Bit of an update.
At 19 PSI (boost controller turned off) it's best run was 417 rwkw at 7400 RPM . That stupid missfire is still there. A few theories floating around at the moment. A dud valve spring or injectors (although AFR's are holding true even when its doing its silly noise). Yavuz did make the comment of "there is so much left in this".
We turned the controller on to do a few tests. 26 PSI was all in by 4300 RPM. I did see 375 rwkw by 5000 RPM (at 23 PSI I think) which is pretty close to my goal of 400rwkw by 5K! Yavuz did say we are looking at 440-450 rwkw. Considering cams have not been touched yet, it's looking promising.
Also. I switched across to an ECU called "Blackbox". Unigroup run this in their Racecar. Its been made into a plug-in version for our cars. I only ditched the link because I ran out of input's on the Link. Ethanol Content sensor's, Oil pressure, fuel pressure, wideband blah blah. Yavuz made me jump in the seat and have a play with the throttle. It's so bloody touchy! I noticed this change going from Power FC to the Link, but it's that again.
Mad stuff. That black box is freaky!!
Guy plugged it into my 34 along with MAP hose to ECU and started and run after a minute configuring inputs etc on his laptop.
Then Paul made my engine suck a rag.......eh Paul :no:
417 on 19 pounds .. This is gonna make some when its sorted properly and you turn the wick up .
Hopefully you get the miss sorted soon .
Btw, what cams are you using now ?...or is that something your keeping hush hush on .
Sorry about that. I was trying to help by cleaning your pipes out. :D. We are going to run fuel temp compensation just because we can :D
Yeah the miss is pissing us all off. Stupid thing. Cams are between 258 and 262 with + 10.8mm of lift. We ground our own as we found the JUN and Tomei ramp rates wern't aggresive enough! Yavuz has since made a more rampier cam. Bugger bucket and lobe wear. Give me air! :D
Gotta breathe!!....says me with stock cams haha...
Miss could be down to a trigger issue, a tooth is just that tiny bit out at x RPM.....
Just poking in the dark!!!!, as you guys have been through the plugs, coils, ecu ect...
There are no flashes on the trigger box inside the car. If you hold half throttle it'll go to 8,500-9000 RPM without an issue. It's just when you load the farker up! Every single run it does it. Injectors are first then go from there :(. FFS, I just wanna launch it and row gears!!!!!!!
Jeez, that quite a bit of lift and not as much duration as I thought you would probably be using .
Dont need 280's\290's in a street car. At some stage we will be going smaller duration (about 255ish) but more lift (11.3 +). See how that goes.
Also, this is all using the factory airbox!
sounds very promising Paul.
Be really keen to see how she pulls once your miss is sorted and 23psi of pure love ;)
It'll be tuned for 25. Gonna do a "hero run" at 30 to see what these little babies can do. I'd say they will be all over by 25 psi but whats one run? haha.
I'll probably dial the intake cam back a fraction more the get more midrange. See what the engine likes.
Your engine sounds very similar to what mine is ( capacity & your intended power level ).
I wasn't entertaining the use of 280's or 290's...but was thinking something along the lines of a 10.5 & 268 , since one of my old JUN's is now damaged.
You have now chucked a curve ball at me in regards to the cams I will go with ..so I eagerly await a proper figure once sorted from your test mule . :D
And I will be keeping the factory air box , but using a large carbon duct to the bottom of it that came off Geoff fear's gtr .
Edited by ezy_09s
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
