Piglet's Rebuild Of His Busted Tomei 2.8
Yep. It has been mentioned by a few people in the know that a lot of the jap brand name valve springs do not have sufficient seat pressures when they are fitted without setting them up for intended use.
For example, a high boost/ high lift setup would need a modified seat pressure to suit, by either a correctly shimmed spring, setup to avoid coil bind.
Or a dual valve spring such as BC (brian crower) etc.
Due to Paul's fairly non standard setup, seat pressures could definately be an issue, as opposed to most people on here running bigger duration but not much lift and mild boost....
Or I could be just adding my 2cents lol...
^ lol Aggroman
He's made his mind up....that is all :)
Annnndddd 450KW :D
I asked the same thing about trigger. He said it was fine and no blips all the way past 8500RPM....
Have you ruled out the crank trigger system?
No fault lights are coming up when it happens and it sounds different to say a coil breakdown or the timing out.
that is a very valid point - i remember once my intank pump sucked up a piece of rubber from 1 of the mounts & it sat in the inlet (had no fuel pump filter, not my doing) and symptoms were slower revs
maybe slower fuel delivery?
sounds like fuel to me Paul. Have you cleaned or replaced your in tank filter.
I had a similar problem in the gtr Marko. car would miss under load but you could feather the throttle to peak revs no problem.
The in tank filter was munted. changed it out and presto! all good.
I had the exact same problem. Under load above 4000rpm (dependant on load situation) both on road and on dyno (ramped, etc) when accelerated hard my car would have a miss and sort of hesitation. If i eased on the accelerator, the problem did not occur. We changed fuel pump, had all injectors flow tested, etc, as they are brand new, and car still hesitated (missed). I WAS running NGK platinum plugs (gapped to 0.8mm) and the car still had same symptoms (exactly like you are saying). I have super tech valves with titanium retainers, etc, 1.5mm overized valves stainless on intake and nitrite coated on exhaust. My springs are 95pounds at the seat and still car hesitating under load. Problem was found that my spark plugs were arching out under load. (Simple rule of thumb for old school mechanics - plugs up top, points down low) checked my coil packs, they were fine. Changed the plugs to v-grove and solved my issues instantly. Have also since put SplitFire coil packs and HKS plugs. I was running 12psi when this was occurring so had nothing to do with coil binding or a dud valve spring.
That's just my two cents. Hope this info helps.
If running E85 you may need to change heat range of plugs and re-gap them smaller. Give it a run on 98 and see if you have the same miss. I was having this problem on my car but only on e85. swapped to 98 and problem would dissapear. Turned out to be a cheap and easy fix after i had spent hours chasing bugs.
Tried that. Nothing has changed since the night it died. Plugs the same type (just new ones gapped to the same as what they were, coils the same, fuel the same, ecu was the same.
I'll ring tomorrow and see how they went.
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
