  On 12/03/2013 at 6:31 AM, Jimz said:
I had the exact same problem. Under load above 4000rpm (dependant on load situation) both on road and on dyno (ramped, etc) when accelerated hard my car would have a miss and sort of hesitation. If i eased on the accelerator, the problem did not occur. We changed fuel pump, had all injectors flow tested, etc, as they are brand new, and car still hesitated (missed). I WAS running NGK platinum plugs (gapped to 0.8mm) and the car still had same symptoms (exactly like you are saying). I have super tech valves with titanium retainers, etc, 1.5mm overized valves stainless on intake and nitrite coated on exhaust. My springs are 95pounds at the seat and still car hesitating under load. Problem was found that my spark plugs were arching out under load. (Simple rule of thumb for old school mechanics - plugs up top, points down low) checked my coil packs, they were fine. Changed the plugs to v-grove and solved my issues instantly. Have also since put SplitFire coil packs and HKS plugs. I was running 12psi when this was occurring so had nothing to do with coil binding or a dud valve spring.
That's just my two cents. Hope this info helps.
I'll mention this when I speak to them today. Cheers for the input ;).
Paul I know you mentioned the timing looked good but might pay to call ross about the trigger kit a local company here in bris was having miss fire issues on there car and they traced it back to something in the trigger kit arrangement. Sorry this is second hand information so i dont all the details but thought was worth a mention..
We had what seems to be that issue you're talking about in 2011 when I put this kit on. The issue for us was the GT101 sensor was not PERFECTLY in line with the trigger wheel. New bracket has since been made. There's no logs of issues with timing or anything. When we had that issue we were seeing RPM logs of 86,000 RPM, 44,000RPM and would be hitting the RPM cut. Sound similar?
Again this is second hand info but they were talking another revision something to do with the cam sensor though.
How long ago was this?
I heard pauls testicles had shrunk so much he has started investigating plastic surgery to have a vadge grafted onto himself? Who woulda thought an electrician would have small balls?
On a brighter note, hurry up and launch it brah
skidz for kidz, or fatz maybe
  On 14/03/2013 at 9:32 AM, ezy_09s said:
Any updates on the strange miss yet ?... Want to see the figures this will put down in anger .
Sitting here with Yavuz in a hotel right now. Nothing happened today. As soon as I know it'll be up here. ;)
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 馃槢
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
