:P .
It had to happen!
OK. So the rears are going in today. Set the heights as close as I can and continue cleaning the engine bay. Yay!
For sale: Nismo S tunes for 33 GTR.
Great looking R-tune's you have there. I'll be interested to hear how streetable they are compared to the S-tunes. I want that adjustability of the Rtunes, without added harshness. Ie... no rougher to drive than the s-tunes.
Ian, They're alot firmer than the S tunes for sure. I have had them in and did maybe 100 kms but 36 hours before the Nats I had to pull them back out :domokun: . I don't really drive the car that often on the street so I spose I can put up with it a little. The S tunes are great on the street but feel a little lack luster on the track. The R tune spring rates are 12 F and 10 R IIRC, so yeah, firm.
Just wait till this years nats, i'll chuck you the keys and see if you like them or not.
Annddd the rears are in :D
I'd like that but won't be making it to the Nats this year. At the moment I have a choice... go to the nats or finish my next engine. Only if work picks up a lot over the next 2 months can I consider doing both.
A few goodies turned up today.
First my crank
Second my quaife front diff centre.
Pistons arrive next week sometime. Sump will be dropped off to Racepace in Melbourne to get modified to their specs. 9.5 Litre oil changes will get exxy!
is that diff a 1.5way LSD?
It's a.... Different diff.
They don't have clutch packs in them, they have gears.
Gav and R32TT (Matty) have them in their cars and love them to bits. They do the same sort of driving as what we do so that was good enough.
Time will tell.
looks nice paul.
That extra oil capacity is good insurance, only 2x5ltr bottles :)
Cheers karnt. Yeah, running round on semis and a stock sump isn't the smartest idea. Us NSW guys and our SBS (sump baffle syndrome) as Ash likes to call it :D
You have the N1 pump syndrome too lol
u better watch for those piggaz when u get it back on the road
Pics fresh in from the land of the rising sun.
A few pics of the head.
The 'marks' on the face of the head is just sticky gunk from it being packed up. A little bit of petrol and it will be sweet.
New 87 mm Tomei pistons with Ti top ring and Valve relief so I can run Vcam in the future if i want to be a dickhead.
HKS Step 2 valve springs.
JUN Ti retainers
Some pretty Tomei stickers :D
Parts missing are the exhaust manifolds which are matched to the head and I sent a manifold to turbine housing gasket to japan to be matched up.
Cams are missing
I also had a 'balance tube' port matched up.
Parts will come in dribs and drabs to not get anally bashed by customs!!!
Block and rods were taken down to the engine builder on Friday. When the pistons arrive the crank and the pistons will be taken down. Head will be in the country on the 12th of May.
    • And also there were for sale scams and the like. For sale posts need piccies, and not having piccies makes it harder to do a driveby scam.
    • And I forgot to add my *** footnote to the above post, which was that the pipework mods would be even more significant than what had to be done for the highflow. So just add that onto the list. Pipework mods are no killer, just made the tasklist longer at a time when extra tasks were not welcome.
    • I mean he could post them to imgur or the like and create a link. But yeah, spam bots absolutely will post pictures in their first posts.
    • Ah ok, reason I asked was for the sake of not having to upgrade everything if the turbo couldn't be capped.
    • pffft! My alignments are starting to take 3-4 weeks each. Bugger overnight - that would be a dream! Overnight is when I leave it on stands with the rear suspension in pieces, hoping I can remember where I was at when I come back to it. I have to set the car up on a level surface so I can get decent camber measurements, then try to set the RUCAs to the right length to get that right. Then I have to put the car somewhere else where I have enough room to set up the bumpsteer gauge (laser, paper, mirror), so I can dial out that. Then I need to go measure camber again because changing the tension arm length affects that also. Then I need to measure toe, and I can't do that to my own satisfaction at home, so I have to put it on an actual aligner. Then I have to go back and fix the camber again, and if that took more than a half a turn, decide if I want to set up the bumpsteer measurements again. I previously had the bumpsteer almost completely banished and then I started changing things again! And that's only the rear end. Not even gotten to talking about the front yet. And this has been going on in the context of me discovering a seized bolt in the LHR FUCA bush at the upright, hence needing total disassembly to replace that bush and the others that were not far away from the same outcome, replacing sphericals in the front end and making a mistake that resulted in needing to do it again, which is only half done right now. It's a selfmade nightmare. Only have self to blame, etc etc. But regardless, I am so complelely unable to utilise the services of a normal wheel aligner that I have no choice. I haven't found a shop in my city that does "race" alignments - and by that I don't mean I want my car to be set up for racing, but the set of adjustments that I have available and that need to be used to do the alignment are the same as you'd find on a race car. I haven't looked everywhere, but there doesn't appear to be the equivalent of the motorsport focused shops that are present in Sydney and Melbourne. And such an alignment would cost $300, and you only want to do it once in a while, and you don't want to find out that you have to replace bushes and bearings and such while you are spending that $300 so you have to come back and spend it again a week later. So I stay living in my self made nightmare for the moment.
