Lovely T curve, when you change at 65 it should put you right in the fatty area of the T.
I am super keen to watch and listen to this thing punch through the gears.
Be careful with that gearbox.
It's an OS 5 speed with a billet centre plate. I would want to cope with the power. A bit of mechanical sympathy goes a long way ;). Bugger 1st gear but. That takes it like a whore!
you remember my sandwich plate has 2 spots though. so one for pressure and one for temp.
Otherwise maybe u need an inline temp sensor if such a thing exists, but that would only work if the thermostat was always 10-20% open
Yeah that is what i am going to do. Assuming its a Greddy adapter you have 2 spare bungs and Greddy in Sydney have the adapters in stock :)
Little update. I was out there yesterday and all the oil cooler plumbing has been (re)done. It was an abortion how it was thrown together before the nationals. Oil pressure sensor is now wired into the ECU so ill have some cutoff if something happens. Today's job was to stage the feed pumps. Tyres also arrived. Apart from the flex tune it's done! Pickup Friday I'd say.
Here is a quick video of it idling warm. Idle speed is about 950 RPM. http://i1068.photobucket.com/albums/u457/Ptriffitt/431B53FB-80D9-4FBE-BF1B-4D7EA42C50DC-9363-000001CBDE8AD41C_zps6979879e.mp4
Being the "standard homo" that I am, I'm gonna leave it how it is instead of mega grumpy. It almost sounds like a standard car with an exhaust!
Cool.
I see that your car has twin exhaust pipes instead of the usual cannon style muffler.
Is that to try and keep errrrrr.......more standard look?
That's how I bought the exhaust. It's a Racepace twin 3 inch and I don't think they make anything with that look.
Nice to see the car beginning to take shape Paul. I've seen it a few times in there, last time when Mark had the cam covers off working his magic.
Liking the result with the Black Box too - Yavuz has been chatting to me about this being an option. Are you just running dual map, or gone the E-Flex route?
That would have been the valve springs.
Full Ethanol Content Sensor. Bugger that duel map stuff.
May have to probe you about your flex setup so I have some ideas when I turn to that route too.
Not sure if you've been down there the past week, but you've probably seen the blue 34 lazing about not doing much.
Seen it mate, nice car.
Yep no problem. Any of the boys will be able to fill you in on the setup.
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
