Haha if u wana be dickhead...u have a way of writing emails which cracks me up.
Those pretty stickers are good for your toolbox.
U running tomei exhaust manifolds right?
:D.
Nah mate. HKS ported me a set.
I learnt the hard way with stainless junk!
:D.
now I remember when the tomei items cracked on u. Do u mind sharing a pic of these hks manifolds, when u get the chance?
this thing is going to be off its head!!!!
Yes, I believe it will, I'm thinking when it starts up Satan will be wanting to sponsor it and any red blooded male with get a warm feeling in their pants.
I'm more partial to a startup engine sound that induces a feeling of fear... Oh crap what have I built ! Instead of one that provokes a bunch of guys to get a semi...
Fear is where its at!
So no VCAM just yet... Are you still planning on using the Mines 10mm lift cams you were talking about at the nats?
Ian. No Vcam yet but I put the Exhaust cam in that HKS and the guy that built the head recommended IF i decide to go that way later on. Actually even without Vcam Hiroyuki recommended the 264's anyway. I will be getting his 'recomended' cam settings and go from there. I'm hoping the idle will be nice and smooth, not a grumpy prick like it was with the 270's.
But fear gives me a semi
Next time your scared... don't come near me :P
Dont be near Wakie on the 19 of May then, the fear levels may drop after the first session if the engine bay isnt covered in oil.
Im loving the power of the boat ATM but the oil issues are breaking my balls, hopefully will be fixed after the new cam covers/baffles and catch can are in.
Either that or Im just going to go and buy some Drag Radials for the rear and only go in a straight line, the car has no problems doing that, stupid f**king car.
Well hopefullt this does it. You can't have any more black lines in your bay. It will look like a spiders web.
Have you got your latest graph handy? Throw it up if you could be bothered!
