The funny thing is whenever u stepped on it, u had to turn it 1/4 turn to the right - i know that the back wheel was out of alignment but this was the same as Domonic Russo's yellow r32 gtr which was making 650awkw where he had to counter steer to keep it straight.
GTR's get massive torque steer in the front with decent power. Check out this video (the wheel alignment is spot on), in the first 3 gears it moves over a car length left and then in 4th I actually drive back onto the "racing line"
Edited by SimonR32
Rightio. The suspension stuff got started today. The sperm whale got weighed and some of the geometry measurements taken today. The porkie pig comes in at 1580 Kg with 1/4 tank of fuel. A little lighter than I thought. The only thing I have taken out is the spare wheel, jack and some of the boot lining. Apart from that it's all standard.
FC872F61-6E4E-47C9-8B47-F98E1F01BA01-662
74F8DCD0-DFD7-4B30-B5E4-D508B9FDFC4A-662
11ty strings everywhere. Tomorrow the shocks will come out so they can measure travel of this that and the other then go away and put together a combo. It'll be basiccally setup for "tarmac rally" which is pretty much what i'm doing with it. Hillclimbs and goat tracks like Wakefield park. Turn around time is between 2 and 4 weeks depending on what Bilstien has in the country.
Well isnt the r34 the heaviest of the gtrs?
Wat lap times u aiming for at wakefield?
Yeah they are, but an extra 20 Kg IIRC.
Times, who knows. I did a 1:10.02 revving to 5000 RPM last year. I solid 1:06 would be nice. It's the muppet behind the wheel that needs to practice :P
the 33 is the heaviest, my 34 came in at 1480 with 1/3 tank, but the tar was removed before I brought it
I remember your blue 34 in the garage.. Very nice.
I could have sworn the 32 was the only Gtr under 1500kgs
that is also what I thought/read
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
    • Welp, you've got a long list of experiences right there. I'd say you're on the right path.
    • That's correct, suits my requirements a bit better. Sure there are also numpties there, however it's generally a different vibe and more my kind of vibe.
