83747408-BDED-481D-A4E9-C644DF3AA119-142
Picture I took this morning with all the covers on. Still need to order a new radiator shroud though.
Also one of those radiator deflector thingos to cover up the horns and A/C fan etc :)
Stop being a lazy fkr and come pick it up :)
Yeah, ill get there!. Time has not been on my side! Grr.
Question for you Nick. Where is your GT PRO set to? Mines at Medium and it's one aggressive mofo. I may need to back it off a tad.
I need to find an ARC one. Not a fan of homo carbon crap.
I was trying to get an ARC one originally but come across my Alloy one on Ebay randomly! Was already sprayed black too :woot:
Black... The new... Shiney? Lol
I remember when first speaking to Alex @ Plazmaman about 3 years ago and i was ordering the stealth kit and he said that Black was to be the new Chrome :P Its Black Bling!
Id have to check with the boys that installed it, im not too sure
raidator guide
tits on a bull
Not when you are talking about the cosmetic stock looking finish! When you pop the bonnet and look down it look a bit average without it! He has gone so far with the presentation it might as well be finished off properly ;)
question, how does the air get to the air box intake if you block the airs path from the grill with the radiator guide ?
You can see the big gap in mine so it would still flow plenty of air... Although I haven't worked out a snorkel setup for mine as I wasn't clever enough to use a stock airbox :(
Oh yeah, scrap that idea!
Im sure brad at profab would be able to fab one up out of sheet ally and in corporate a funnel to the air intake from the front grill.
Then just paint it or powder coat it the new shiney lol.
:yes:
Mine had a shield/guide but it also had a 100mm hole in the guard with some NACA duct tubbing from under the air filter shield to the front grill, plus there is a heap of air voids around the front headlight to allow air to flow inside the air box if it has a opening on the front side behind the headlights.
No good for the ARC box I believe though, but good for a enclosed pod set up.
LOL, just saying.
Rightio. SO after 2 days of 11ty strings around and under the car, deflection gauges, tape measures, more strings, more measuring and even MORE STRINGS, I have a piece of paper with words and graphs. 7 pages of graphs and jargon that I hardly know what it meant.
From what I CAN gather from it. I will need to purchase a roll centre adjuster setup for the front. the HICAS lockout bar needs to be moved up 10ish mm to help eliminate bump steer in the rear. (Design fault possibly). The shocks will be Bilstien with a PSS9 body - That's where the similarity will end. From then on its all Dejan's specs. His valving, gas, spring and oil combo. People may laugh, but the spring rate in these will be about 20 KG/mm BUT it will be very pleasant on the street. They will be height adjustable and damper adjustable.
A little bit of testing and these will be available for R33 GTR's as a bolt in kit.
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
