No new graphs mate, I really should get one, LOL.
When I get my fuel system sorted (was >75% duty at 414 I think from memory) and run 30psi through the TO4Z Ill get one to post up.
Maybe next year
They have taken a fair amount of material out around the valves!
I spose because they are 1.5 mm OS. The head was originally modified for the 1.0's. After it came back from NAPREC Hiroyuki took out a bee's dick more for the extra 0.5mm.
See how it goes eh?
Crank and pistons dropped off this arvo. That should not take too long. Head is less than a week away. Double check CR. Going by my calculations a 1.2 mm headgasket will bring it to 8.5:1.
whats the deck height? Are you aiming for a tight squish for this motor?
Block hasn't been decked at all. Head has been decked 1.0 mm at NAPREC. We just have to get the head here and take some measurements. From what I can gather the chamber volume is 66.5cc but that's got to be double checked.
Not sure if you have read my thread if not please do so as there is alot of info about squish and its advantages
I remember something about a 33 thou squish. How does this change when one of the pads have been removed?
i guess they have taken the intake squish pad out so you can still set the squish with the one pad all it means it will push the air and fuel towards the intake as this will be the cooler side of the chamber. If your looking at running big boost, this will help it from detonation
Update here, doing it for Paul cause the pics were taken on my phone.
First is dropped all this stuff to Chris at Craved Coatings (look them up, really good work and very reasonable prices) for ceramic coating. This will be back in 2 weeks;
Next we went to where Marcus had sent the head (Unigroup), this is the first time it's been seen and has only been in the country a few days.
Typical Marcus wrapping, it's bombproof!
Awesome that he left the flight stickers on - Marcus brought it back as carry on luggage on the plane haha!!!
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
