Prob should update this.
The last few weeks its copped two new 044's. My primary feed pump wasn't playing ball do they both went. As a result, my idle is grumpy and my cold start is junk due to the increased fuel pressure at idle. It goes in tomorrow to get this fixed up and chucked on the dyno for a quick health check before these track days coming up.
It also copped two new front drive shafts as I did a boot on each side. The passenger one was clicking. Grease everywhere!!!!
Ordered some new brake pads. These 2500's just won't cut it. Damn heavy whale!
New front diff oil yesterday.
Coolant bleed.
New engine oil tonight ready for dyno thrashes!
Having front sway bars link washers turned up. ATM, the front isn't connected. It's a tad taily but it makes it interesting!
Good to see what u get and how much boost u going to run on the -5
The most we have run is 28 psi IIRC. A graph is here a few pages earlier. I normally just leave it at 25 psi.
Let it be known I have experienced this car and it was a dead set ballistic missile.
Gears would wind out in the normal 'extremely fast car' manner, but each gear would account for a lot more than the usual 'fast car' speeds. IIRC 3rd gear was well over 180kmh and it got there like it had tiny short ratio. The most amazing part was the brakes, powering through 4th with less than 100m to stop I had to seriously consider if this was the end, but the car didn't even break a sweat.
Paul, your car really got me buzzing, I couldn't stand still when I got out. Cheers.
now that's the kind of feed back I like to hear :)
Hopefully u can get that fuel issue sorted out Paulie.....sounds like a bit of a pain it I'm sure it will be fixed.
Would love to see track footage of the sperm whale in action
Lol, thanks man :)
  • Like 1
It's just a quick adjust to a few cells. All good
I'll have a few vids of this coming Tuesday.
Awesome, look forward to hearing how the tidy up goes :)
Agreed with GTScoTT - best all around GTR I have experienced, I said it at the time... but I was looking forward to seeing how the -5s and 28 (along with cam choice etc etc) worked together but what actually REALLY wowed me was just how well put together the entire car was, and those brakes! Fantastic car, would be a weapon on the track :)
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
    • with the car running (runs fine when temp is cold), I unplugged the MAF and the car stalled.  I have already cleaned it a week ago.  I unplugged the O2 sensor from the left side of the vehicle, and the car was still running.  I let it idle for about 5-7 minutes and shut it off, to see if it would restart, and it did not.  It cranks but doesn't start after engine temp gets up to normal range.   I still need to look at the coolant temp sensor, is this one at the top or bottom of the radiator? Or is it one of the sensor threaded into the T-stat housing?
