Have you thought about getting the nismo getrag conversion for your r33? I know its a bit expensive but surprisingly you get a fair bit of stuff for the money and its all new including the box
http://www.nismo.co.jp/en/products/competition/mission/getrag.html
It is an option. You don't hear of many going bang but really, how strong are they?
Getrag and 4.11's would be crazy short. I'd say there would have to be a diff ratio change in order.
What is the Getrag's limits? I know PPG do a set for them but that's the best bit of $10k for the spikey wheels and associated bits themselves.
PJs Helical dog has had one dog ring changed in all the time he has had the box in his car.
75% is street driving plus countless 10,9 and 8 sec passes.
His car hooks better than most AWD :)
How long has it been in the car?
First hand.
I owned a straight cut dog engagement PPG box for about 4 years. Drove it occasionally on the street, mostly in tarmac rallies etc.
It was rebuilt/refurbished every year without fail, regardless of how it was treated. They just don't handle power as well as people say.
Paul's car will certainly stretch it's limits with 470kw on tap.
These boxes prefer to be shifted hard, the slower you engage the dog rings the more damage you do to them and the gears. It's not always apparent until you pull it down just what slow shifting (street type driving) does to the box.
I sold it and went Holinger. My Holinger is helical, not sure if they all are. It's quieter and easier to drive at any speed without doing damage as a result.
I rebuilt my Holinger pre WTAC and parts alone was $5k! Nothing's cheap or bullet proof when you're chasing big power unfortunately.
There's no simple answer, other than keep saving your hard earned....
How long was the Holinger in before that?
Too much servicing costs, bugger that!
Terry just rang. 6 speed won't cut it, he does heaps of them. OS there is a massive delay and won't cut it anyway. He is looking into a custom straight cut set with a helical 5th that's synchro which uses the Series 3 internals.
*waits patiently*
What it comes down to at the end of the day is cost and luck.
I can afford to put stockers in every year or so, I can't afford a big $$ box then have it pulled down every 2 years for inspection and then possibly replace expensive parts. Billet selectors are $500 each for example.
On the other side you can have a freak stocker or freak billet set last for years and years.
It's just such a jerk of a job.
The stocker didn't last at 370.
See what sorta prices Terry comes back for this custom thing. If its reasonable, I have 4 mates that will snap one up too.
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
