I agree, turn down the wick mate and enjoy...besides, your car is stupidly or cn I say dangerously powerful
slap stocker box in
adjust wastegates to 17pis
enjoy for a long time without issues
will save you 7k
downside is less blokes on here humping your leg due to awesome output
It's at 25 psi man. Hardly "screwing its brains out" and realistically I haven't run over 22 psi at all which is less than what most people run on -5's. if I turn it down I may aswell drop back a turbo size. There are associated costs with doing that too.
sorry to hear bout the box :(
interesting though, with E85 and new turbo tech, starting to really push the boundaries of what street cars would normally have to contend with. Maybe you'll create a market for a street-able bullet proof gearbox option - but you've unwittingly created a bit of a "ceiling" for what people might be considering build wise as well... (With respects to gearboxes)
not sure if it's of much help, but i recently found out i have 33 v-spec ratio diffs (like a god damn kinder surprise this car) soooo... i have a getrag and 33 diffs... if you're in melb anytime soon, you're welcome to take it for a drive if you like, see what you think. She might be a bit slow for you, but she goes alright :D
Torque ratings ain't high enough. Try again lol
Phone them. I bet higher ratings are available.
If you had a high reving 2.6 with less torque, this wouldn't be a problem.
Edited by black bnr32
I believe he is in Vic ATM for DECA this weekend, what revs does it sit on at 110
go on Paulie get the OS88, you know deep down you want it, and then I can take it for a drive and see if I want one :P
What timing! I'm actually in Melbourne right now! Thanks for the offer Dan. Flick me your number so we can organise something. That would be fantastic. I've always wanted to launch a Nur spec from 10,000 RPM :P
What a great clip.
that thing is an animal!
Is it just me or does the gear changing sound slow for a sequential box? I don't know much about them so maybe there is a setting for gear change delay.
may the sequential be with you... always
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
