Why did you build a 2.8 and use an n1 pump haha, was lucky you made it that long without letting go!
I bought the car off a mate like that. That engine was built in 2005. It was always the one thing that I was worried about.
And I kept telling ya I had a tomei one under the bed with your name on it whenever you wanted it.
On a serious note, could the damage to the box have been done previously (pre this engine rebuild) when possibly the owner gave the car a bit of hiding now and again.
I'm talking possible microscopic stress fractures that may not have been visible during the boxes recent rebuild and with the new sandwich plate and diffs maybe no torsional give, well something gave.
Maybe time to pull that black carbon giant dildo out again that could help with torsional loading ???
Whats the damage diagnosis ?
Marcus, I built this box about 5 years ago when I smashed the OEM box. That was a shock loading through my own fault.
That big dildo is long gone. Stupid POS!
Need to get it out and inspect. If (hoping) the gearset has survived (not liking my chances) ill put new bearings through it and whatever has failed then screw it back together, but from what Terry has said, it's a shock loading more than likely. When I did it, I'm not sure.
Not sure when I'll get to it with Xmas and shit coming up. The plan is ill wash it and drain the E85 out of it and flush with some 98. The car ain't going anywhere so ill just take my time.
We already told you to get an Air Shifted HKS box........... stop being a pussy
And i dont care if you cant downshift :P
Is that what we decided? I don't remember.... No idea why! :D
What about this mad RH9 box : http://www.rh9.or.jp/original-product/products-list_mission.html
The one at the top of the page. Chuck the link into google translate as can't be bothered translating as been speaking too much ping pong of late and on the beers.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
