Some sort of progress.
Emailed PPG yesterday and asked if they will do a straight cut 1-4, helical 5th synchro box for me. They said yes!
Waiting on pricing.
They did say, it would be a good idea to go to the bigger input which will mean clutch modification, so ill male some calls with that tomorrow.
When you removed the Active LSD did you have any issues with the ABS not working anymore? Did you replace the ABS computer or leave in the one it already had?
No issues with ABS at all.
When I changed the front diff it played havoc with the rear though.
Waiting on pricing.
So will it be syncro straight cut 1-4 helical 5th?
Yeah mate.
Not keen on dogs and I can deal with a bit of noise in the lower gears.
Apparantly PAR do what I'm after but I want a PPG set.
This set will use all the Series 3 33 gear inside, so servicing shouldn't be a drama.
Should have a price tomorrow.
At the end of the day, it's still a street car with full interior. I don't mind chucking the keys around, so if I have a hard to use/expensive to repair box, it sorta takes the "easy to drive" away from it.
Will the straight cut fix the 2-3 issue if it's still syncro? From my time with the dog box think I'd rather the dog gears than straight cut especially at your power level shifting speed is so much quicker. After some practice u get pretty smooth mine lasted 4 years and probably 15k km's without issues or servicing until I sold it.
Bah. The guy misunderstood me with what I wanted. They won't do the "mix n match". He is trying to sell me the dog set, saying his old lady drives it no problems.
Well you do have a tiny shaft.... so probably a good thing to get an upgrade :whistling:
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
