I haven't really taken any mate. Car isn't at home at the moment. Are you looking at doing a twin 3 inch?
Yea mate, I'm doing a twin 3inch on my 32. I got AES building me some custom mufflers ATM, so I won't have any clearance issues, mine will be alil diffrent, as I'm running twin 3inch to the diff and than 4inch into the rear muffler.
Rang NPC and Exedy today. Exedy were pretty damn helpful. What I need is the dimensions and tooth count of this spline hub. They might have something off the shelf which might suit me to a tee and just plonk it in my casing. Sounds good to me.
Basically its tuned length front pipes, into a muffler where the stocker lives which has two 3 inch 'holes', twin 3 inch out then it joins into one piece around the diff. Not enough room for two pipes. Then back out into twin 3 inch, muffler then twin tips.
yeh those tuned length front pipes in particular is what I wanted a pic of, just to get a rough idea on how they went about em, as theres so many different ways to run em.
Cheers
Deano
Cheers
Deano
I know the rear one wraps over the front pipe. Makes getting them off an absolute bastard.
I just went through my photobucket, no pics of the fronts there :(.
If Exeedy can't supply a centre hub for your clutch to match your input shaft, they may be able to provide you with something that will be close. Ie, sharing the same number of splines, but a fraction too small for the shaft.
Given to a machine shop with a CNC EDM wire cutter, they could quickly re-cut the spline to suit your requirements.
I've heard similar good reports about the NPC carbon clutches too. Streetable etc. There was a guy up here with an 800ish hp R34 that used an NPC clutch to allow the holinger box to link up properly. My exeedy carbon D twin is taking some getting used too. It tends to slip when its cold, but get it hot just once and it holds really well. It would be interesting to know if the NPC's also have to be up to temperature to get them to hold.
I'll see what comes up in the next few days. I'll get the relevant info off PPG and go from there. Thanks for the info, Ian!
I had custom tuned length front pipes on my GTR years ago, it definitely kept the gearbox oil warm
And the heat that comes through the floor, esp passenger side. Jesus!
  • 2 months later...
Nothing yet, Eric. Car is still at the panel beaters.
Oil still hasn't been drained out of the box yet lol.
Michael Hill has given me his spare stock GTR box so hopefully over the Easter break I'll get it in then get my one stripped down.
I am considering putting a PPG dog set into a Getrag. The ratios are pretty sweet, even with the 4.11's, although would be better with the taller diff ratios.
You're having problems finding a center hub for the larger input shaft?
I had that problem when I went with the PPG dog box and larger spline input. Ended up going with a twin carbonetic clutch which has the optional center hub that fits the ppg input.
Edited by NismoSTune
That's good to know, cheers! What does it drive like?
I'm really liking this getrag idea. Does anyone know what tail shaft to use with the Getrag in a 33? I know you use the R34 front shaft but not sure on the rear. I'm assuming the 34 unit also?
    • Thanks for advice chaps   so you would change idler and tensioner bolt as well ? I guess because you thinking they have stretched once ?   i have done some research and on nissan belt and seem to hold 700hp but thinking HKS to be on safe side   i think I put nissan there last time   also thinking of changing cam cover to glass style:)
    • Nissan/Pitwork is fine stuff. HKS is just marketing wank. I personally wouldn't do the idler if it is already new. If it looks and feels fine, it is fine. But as D says - it's cheap to add it to the job. The water pump ditto. Even more so. If it show no signs of problems, then it is nearly new - leave it.
    • 1. I can't see a location on your profile but you do mention GBP so I'll assume you are in UK. In Australia, CBC make a timing belt kit with the gears and idler and tension bearing and that is what I use without any problems. I'm sure OEM or HKS are also fine but I wouldn't pay extra for HKS over anything else. 2. Yes, I would always change the idler and tensioner and the stud and bolt that hold them in. Assuming they were all done last time it is highly unlikely you would have a problem, but they are very cheap to add to the job considering the time it will take anyway.  3. No, you don't need to lock them as such (I think that is more for engines without timing marks), but you should make sure they move as little as possible once the belt is off as you can hit pistons on valves if they move too far. As always, make sure you line it all up to top dead centre with the timing marks aligned before you take the old belt off.
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
