just putting these out there 7k delivered
older style so ( parts may be hard to come by)
http://page3.auctions.yahoo.co.jp/jp/auction/c435357961?u=%3btokusan707
is HKS manual transmission. There is no oil leakage and noise. Dirt.
It becomes the 6-speed MT. ATS carbon twin plate clutch will also be set.
Thickness of the disc of the ATS clutch is 3.7 mm ① 3.7 mm ②.
Gear ratio of HKS mission is the version Ⅱ of 2.701 ② 1.904 ③ 1.343 ④ 1.000 ⑤ 0.832 ⑥ 0.734 ①.
trust 6 speed 7 k delivered
http://page22.auctions.yahoo.co.jp/jp/auction/l213425216?u=%3btokusan707
trust made ​​dog clutch-type cross mission do. There is no oil leakage and noise.
There is dirt. ① speed 2.782, ② speed 1.938, ③ speed 1.506, ④ speed 1.178, ⑤ 0.920-speed, gear ratio is 0.777 ⑥ speed.
  On 13/04/2014 at 9:46 PM, Piggaz said:
That's good to know, cheers! What does it drive like?
I'm really liking this getrag idea. Does anyone know what tail shaft to use with the Getrag in a 33? I know you use the R34 front shaft but not sure on the rear. I'm assuming the 34 unit also?
I had a Getrag with everything for the conversion and didn't do it... I don't think it was much of an upgrade in retrospect in terms of strength (besides the ratios) and it is generally accepted that they are not rebuildable (even though people do), and spare parts availability is an issue. So I got rid of it... I agree with the fat man.
Everything is available either ex Nissan or ex Toyota, it's the exact same box as the Supra box apart from the rear end.
Always thought those Trust boxes were pretty interesting. 2 overdrives and no 1:1 gear.
They're not the same box. The gtr version, the gears are not as wide.
The getrag with 4.11's will be silly short, but I have a source for 3.545 diff gears. Talking to the guys that have the same grunt, give or take, they have said the boxes hold up. IF it does pop, the PPG dog set will go in. Ratios to die for.
  On 19/04/2014 at 1:29 PM, Marko R1 said:
I'm surprised to hear that the getrag is up for the task
MAY not be, but if I be nice to it, it may last a few years, I which time I can save for what will eventually go into it.
Car has only done 3 kms this year. Need to get back to driving it :(.
Just saying, go sequential, you won't look back :)
PPGs are strong, how strong is a different matter, the BSM car went through a few of em to while they still had restrictors in limiting power to about 300rwkw, very torquey motor though
And for what it is going to cost to set up the Getrag your not far off the OS88
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
