  • 1 year later...
I rang up www.autobookworld.com today asking for the R34 Owner's Manual.
The owner was out, but the employee said they hadn't had one for a while.
He did offer me though, a two volume set of the official workshop manuals including wiring diagrams for the BNR34. The set was expensive.
I called back later when the boss was in and he discounted them after holding them since 2009.
They're in Japanese although English is juxtaposed to Japanese in the index.
Knowing that Maria can read and translate Japanese...
That price became too hard to resist I'm afraid > got em
That 1st volume of course can be downloaded or it's available on disc Afaik.
Hi Terry, I do not care if it is a copy as I need an owners manual as I have no idea about some of the electronics , is there a site where I can get a copy, free or pay is OK . I tried and got the full workshop manual and have downloaded it but NEED the owners manual.
Maybe all of the combos GPS, radio, DVD, Bluetooth , reversing camera etc in the R34s are all different, but the one I have does not even have a brand name on to suss it out.
Hope someone can help
Since you're in NSW Peter...
Haynes Manuals
63 Fairford Rd
Padstow
Ph: 87131400
If they don't have one Peter, you can come up and take pics off mine.
Haynes Manuals
63 Fairford Rd
Padstow
Ph: 87131400
Thanks for that I will give it a go and let you know how I go
See you are in the Blues, great up there, used to go for a drive there a lit , lunch and a beer at the old Hydro, that was a long time ago, guess it is all different now. :unsure:
could not find any on their site I will call them later
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
