So I replaced my ceramic button clutch with a streetable heavy duty organic.
In the process I replaced the spiggot but did not replace the input shaft bearing
(I think that's right, when I depress the clutch stationary it gets noisy as hell, clutch in quiet)
My question is what will happen if this bearing goes unchanged for a while?
I won't be able to pull the gear box out gain any time soon. What will the actual effects be? Or will it just be noisy? It's loud but I feel no actual effects.
https://www.sau.com.au/forums/topic/397688-will-the-bearing-do-damage/
If it is the input shaft bearing, if you keep driving it the bearing will eventually collapse and quite possibly wreck a gear or 2 costing you more in the long run. Did you replace the clutch throwout bearing that sits on the fork?
Sounds like you mean the throw out bearing, which is the one that the clutch pedal pushes onto the pressure plate. Here's mine;
The clutch kits i've seen all come with one. Just change it. Eventually it will fall to pieces and you wont be able to release the clutch.
Hang on OP, you said the noise is there when you depress the clutch and it disappears when the clutch is in...these are one and the same, so which is it?
Foot on the pedal pushing it in...is the sound there?
Foot off the pedal...is the sound there?
Which one comes with an exceedy clutch kit? Spigot?
Nope, the throw out will always come in a clutch kit. Throw out should always be replaced when you do the clutch, spigot is often ok. If the throw out is dead it will squeal when you push the clutch pedal. Spigot is the bronze copper ring in the center at end of the crank;
no. "depress" means you are no longer pressing in, and when the clutch is in, as in you "press" the clutch in, it goes away, make sense?
http://www.thefreedictionary.com/depress
Was the noise there before you installed the new clutch? What kind of noise is it, a whine/grind/squeal/rattle? Which bearing did you replace, spigot or throw out (see MrStabby's pics).
To depress the clutch pedal means to push it down. You can't just make up your own definitions - you'll just confuse people.
So to press my clutch means to let it out ?
Does anyone have an answer to which beating that is instead of more insights to a specific word? I even put a video showing the clutch position can we move on?
I wouldn't assume oil as the gearbox is not moving but more a bearing inline with the clutch,
Is that most likely the thrust bearing?
I'll start off with my usual disclaimer, " I'm no Mechanic but "
It is my understanding that when you are sitting still with the car running in neutral with your foot off the clutch ( I'll avoid the press-depress issue :rolleyes: ) the input shaft is obviously turning at the same speed as the flywheel and so is other stuff in the box, so I'd take on board what turboedsloth says I'm pretty sure he rebuilds gearboxes :thumbsup:
does sound a bit raspy to be throw-out bearing,,,, could wrong,, either way its box out
Yeah box will come out, I guess it's good practice to replace both the throw out - input - thrust bearig just do it all for the sake of doing it while were in their. Are any of them specifically difficult
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
