does anyone have a picture or idea how to run the coolant thru the wastegate properly?
i noticed a coolant hose running thru under the throttle body, could this be separtated into two outlets and used for the wastgate, then where would you join it back in? :wacko:
nuh two are pluged ...................i get what you mean now looks likea going shopping at summitt racing for more dash/an y pieces/fittings...........it would look more trick like that too thanks for the idea fella
    • Mostly likely welded. 'Coz it's f**ked. You have the car right there. Get someone to tap on the underside while you sit in the back with the seat out. You'll find it faster than we will.
    • Yeah, I'm pretty sure that's how it's going to end up. Mechanic suggested I cut a hole in the chassis/body to access the inside. I can cut the hole for access but will have to get someone else to help if any welding is needed afterwards. Things I'd like to know are: Assuming there's a captive nut inside, how's it fixed? And how can it be tightening but not fully loosening? If I cut a hole to access/replace a captive nut, is there a good place to cut for this one? Does it have to be at the side, or is there somewhere I can cut from above inside the car?
    • So i finally got the exhaust done. Full custom 3.5" stainless with dual tipped sp mufflers & a side exit aes dump valve.  Not as quiet on the outside as i thought it would be, but heaps quiter inside when driving and no more drone.  Some pics on Instagram
    • The wasteland, as least traditionally too, was the place with more relaxxed shittery/rules. Not to say you can post porn etc, but it was the place for good joking around, and a bit wild. There was also plenty of unwritten wasteland rules, such as what any user must do if someone posted up asking for likes/votes for a contest... Which was to go in and vote for someone else instead 😛
    • Plenty of people I knew who drifted set their cars up more for grip than traditional "drift", and then just added LOTS of power. Gave them more control, and bigger smoke shows.
