Hi All,
http://www.ebay.co.uk/itm/Nissan-Skyline-crank-collar-RB20det-RB25det-RB26dett-/280849305653?pt=Motors_Car_Truck_Parts_Accessories&hash=item4163ec5035
Anybody know of or has tried these crank collars? They are half the price of the spool ones, but anything that's super cheap usually means that it's cheap for a reason. In reality, the manufacturing cost of these are pretty low i'd guess. So they could be just making less money.
I dunno, anybody?
Doesnt say what its made of nor does it state the clearance. For 25 bucks more get a known one from a local supplier. It may be quality but who will risk it and try one?
It says its made of 4140 high tensile steel, judging by all the positive ebay feedback you'd think it was a well made product.
I am sure the one in the link will be fine..... or you could buy mine which I know to be fine! They are made to the same dimensions as the Jun collar (43.7mm on the round 40.7mm on the flats) as are most crank collars sold. There is no body of solid evidence as yet that bigger (smaller clearance) is better - or everyone would be making them bigger. I offer free postage as well
Yes I bought one of these from this guy. The collar is very good and delivery was quick. My machining guy asked where I got it from because it was better than the ones he had been using.
Also when I bought it I did some research on these items. I found an Australian engine parts / engine building company selling the same items for $150. I can't remember which company it was but it seemed reputable.
I also bought a couple of oil restrictors from this same eBay guy, one had a bit of a burr on it which I needed to clean up but other than that they were OK.
Hi All,
I dunno, anybody?
Actually buy one of these and support a fellow SAU member :P
Good price too.
I disagree. Running too much clearance between the collar and the pump gear is BAD! Very BAD!
It means your still only driving the gear on one side of the flats, it may infact be more of the gear, but its still only on one side. Too much play also causes the inner gear to chatter away inside the pump housing causing the pump to fail.
The guys in the US and Canada are all over this issue.
We've never needed to go anywhere else but Chilton Engineering
Tighe make the collar and Chilton shrink them to the crank with precision. Supplied and fitted for under $250
Don't know why anybody would buy a collar that has grub screws. Seems like a dodgey way to secure it. Like the shift knobs always coming loose
But i like pulling my knob off ....
The grub screws are a belt and braces approach. Collar requires the crank to be machined to provide a shrink fit for the collar - grub screws are an extra insurance.
Yeah I know how they work, I'm just saying that it's a rather poor idea IMO. If it is correctly machined and shrunk fit then it will never need grub screws. They have just copied the JUN collar I imagine
If you think its a poor idea simply throw away the grub screws. The security of the shrink fit depends on the quality of the machinist not the collar.
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
    • Yeah, but "restomod" implies Singer and things like it, which implies drug money / trust fund maturity.
