Well Scott's did 13.9 with more power. It's getting the barges off the line that counts. I have no doubt he would demolish mine in a roll on.
Hope you can stall it up with boost. Will be fast if you can.
Not likely, it wont even start. lol.
Luckily I got it going to get it off the dyno and onto the car trailer, when I got it home the damn thing was hydro-locked. Off with the heads next week for a check, if all's good I will replace the head gaskets, fit the ARP L19's and try again.
nice work guys, i was planning on running tomorrow but weather is shocking so ill have to wait till a day where its clear lets see waht stock power vs. now 300kw does
Yours will be a very interesting run mate, I wouldn't be surprised if you can get into the 12's with better tyres. Lighten it up as much as you can... :)
  • Replies 179
Best I could do was back up my 12.3,
Clutch didn't seem to like 300+kW+Drag launches+fat heavy car and is now rather f**ked.
I wont be buying another exedy clutch as it only lasted 9 drag launches and 10k km of fairly sensible street driving most of it on 280kW.
DVS JEZ what would you suggest? Car isn't driven daily and pedal weight is less of a concern but i would like to maintain some feel and not go back to the on/off switch HKS twin plate i had in it.
Edited by numleg
Sounds all to familair.....I have done 2 trips to the drags and done 2 clutches.....both were built by Race clutch
The 2nd one I killed actually had its last day on the street. It fused the carbonic clutch plate to the flywheel
and would not dis-engage. 4200lb single plate
I have just had a complete new clutch and billet flywheel installed. The factory flywheel was in bad shape with a blue heat ring around around the face where the linings ran. Clutch is a NPC this time. Will see how long it lasts...
The car is arount 1650kg
Trap speed was consistantly 185kph+ this should be good for a 12.00 or faster.
best 60 foot time was 1.8
This car won't see track time only street and drag. I have a 180 for track/drift/stupidshit.
I'm looking at what i can get local today otherwise i will order the nismo compermix comp $2200 from RHD Japan delivered isn't too bad but thats still a lot of cash.
My GTR runs an exedy cushion button twin plate. Even my missus can drive it. Has seen alot of abuse and circuit racing.
How much does ur car weigh?
Wht MPH did u run?
Edited by numleg
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
