Well Scott's did 13.9 with more power. It's getting the barges off the line that counts. I have no doubt he would demolish mine in a roll on.
Hope you can stall it up with boost. Will be fast if you can.
Not likely, it wont even start. lol.
Luckily I got it going to get it off the dyno and onto the car trailer, when I got it home the damn thing was hydro-locked. Off with the heads next week for a check, if all's good I will replace the head gaskets, fit the ARP L19's and try again.
nice work guys, i was planning on running tomorrow but weather is shocking so ill have to wait till a day where its clear lets see waht stock power vs. now 300kw does
Yours will be a very interesting run mate, I wouldn't be surprised if you can get into the 12's with better tyres. Lighten it up as much as you can... :)
  • Replies 179
Best I could do was back up my 12.3,
Clutch didn't seem to like 300+kW+Drag launches+fat heavy car and is now rather f**ked.
I wont be buying another exedy clutch as it only lasted 9 drag launches and 10k km of fairly sensible street driving most of it on 280kW.
DVS JEZ what would you suggest? Car isn't driven daily and pedal weight is less of a concern but i would like to maintain some feel and not go back to the on/off switch HKS twin plate i had in it.
Edited by numleg
Sounds all to familair.....I have done 2 trips to the drags and done 2 clutches.....both were built by Race clutch
The 2nd one I killed actually had its last day on the street. It fused the carbonic clutch plate to the flywheel
and would not dis-engage. 4200lb single plate
I have just had a complete new clutch and billet flywheel installed. The factory flywheel was in bad shape with a blue heat ring around around the face where the linings ran. Clutch is a NPC this time. Will see how long it lasts...
The car is arount 1650kg
Trap speed was consistantly 185kph+ this should be good for a 12.00 or faster.
best 60 foot time was 1.8
This car won't see track time only street and drag. I have a 180 for track/drift/stupidshit.
I'm looking at what i can get local today otherwise i will order the nismo compermix comp $2200 from RHD Japan delivered isn't too bad but thats still a lot of cash.
My GTR runs an exedy cushion button twin plate. Even my missus can drive it. Has seen alot of abuse and circuit racing.
How much does ur car weigh?
Wht MPH did u run?
Edited by numleg
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
