The wrap up;
14.6 @ 158.9km/h
14.7 @ 159.8km/h
14.4 @ 156.7km/h
Each time, I simply couldn't generate the full blooded 3200rpm full boost launch that I can do on the street; time after time.
Frankly I was pretty damn disappointed with the times; it was just so lazy off the line.
After idling the car (in gear), through the session before in an attempt to get some heat into the gearbox, hoping that it would actually come on boost and do a decent; it finally did what I wanted and produced this.
To say I was pleased; is a bit of an understatement.
It left the line with about 7psi of boost at 3000rpm; so there may be more in it once I can get consistent boost control on the line.
Well done to Theo as well; a swag of 13.9's, regular as clockwork.
Good to catch up; top stuff.
Commiserations to Whitestag; hopefully your issue isn't serious.
  • Replies 179
Well done guys. Very consistent times Theo :)
Nice timeslip Dale. Is that about what I said....?
Big improvement over your stock runs, as you'd expect given what you've done recently.
The wrap up;
14.6 @ 158.9km/h
14.7 @ 159.8km/h
14.4 @ 156.7km/h
Congrats dale I feel left behind In the 14 sec club, I want to go to the dark side
Lol, picked it like a dirty nose Leon. ;)
Cheers Rudi; had a quick yarn with your young bloke out there, sorry you couldn't make it.
Catch you soon mate.
I think I raced one of you guys on my last pass before retiring with a blow radiator hose(maroon r32GTR). Grats on the times and very beautiful cars. :)
You went up against Theo (WAGON BOY) and you would've been able to wipe the floor with mine if you hadn't had to bow out.
At least it wasn't a major issue for you then.
Very nice ride mate; the Maroon looked very nice under lights. :thumbsup:
yeah i think that was me, did you get the 11.9 ??? if so awesome time!!!
Dale was infront of you in the black one and i was behind u in the silver one
edit* cheers for the vid :)
Edited by WAGON_BOY
i wouldnt mind going again in a few weeks, once i get my 20's back cos there lighter and once i get the fault code checked and the tune settles in, gotta try and get a better time LOL
Hey theo , let me know and I'll try and go as well , cheers rudi
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
