Hey peeps,
Very limited info on this. I have the oem single din cd unit. Im looking at installing a single din replacement headunit and have a problem with what wires go where. I have hdtv installed so ull be installing the sound into the aux option so thats sorted. Will the nissan harness work with the m35 for easy install. If anyine has done this successfully can you please run me and everyone else.what you did and what colour wires you used. I keeping the factory display .
Thanks josh
https://www.sau.com.au/forums/topic/397702-m35-stagea-headunit/
go and buy a nissan to ISO harness. then an ISO to whatever brand. that way, no cutting of wires.
you might need the antenna connection adaptor also...........
if you have an aftermarket TV tuner, run a pair of RCAs to the head unit from the tuner in the boot. if you only have the stock tuner, i have no idea haha
You can test the speaker wires with a 9v battery, simply place one wire on the +ve and touch the other to the -ve terminal .once you find the pair of wires for a particular speaker ( nothing will happen if you dont have the 2 wires for the same speaker...look at the diaphragm/cone to see its pulsing outward so you know the signal is in phase, if it's out of phase the cone will move in reverse.
Label up and wire accordingly, also use solder and heat shrink, never twist and leccy tape. You will have issues down the track
Ok so went out and got the head unit yesterday, chose a Sony CDX-GT700UI MP3 CD Player with USB/Ipod Function, AUX input and 3 pre outs. i have also ordered a nissan 2 to 1 aerial jack for the stagea. After finding a diagram i got sent a while ago by Leon (commsman) i have figured out the following.
Black - Earth - Connect to Chassis - (Attach First)
Red - Acc Power/On Position - Pin 10 - (LG)
Yellow - Constant Power - Pin 6 - (Y)
Orange/White - Illuminate Signal - Pin 8 - (R/L)
Blue ATT - Car Phone Option - NIL - NOT NEEDED
Blue ANT - Antenna Power Supply - Pin 5 - (R/W)
Blue/White - Amp Ren - NIL - Run to amps
Grey - Front R+ - Pin 4 - (BR)
Grey/Black - Front R- - Pin 3 - (B/R)
Purple - Rear R+ - Pin 16 - (OR)
Purple/Black - Rear R- - Pin 15 - (B/P)
Green - Rear L+ - Pin 14 - (LG)
Green/Black - Rear L- - Pin 13 - (B/Y)
White - Front L+ - Pin 2 - (L)
White/Black - Front L- - Pin 1 - (B/W)
From the GI section "How to read wiring diagrams" of pretty well any Nissan FSM
This shows a code for the color of the wire.
B = Black
W = White
R = Red
G = Green
L = Blue
Y = Yellow
LG = Light Green
BR = Brown
OR = Orange
P = Pink
PU = Purple
GY = Gray
SB = Sky Blue
CH = Dark Brown
DG = Dark Green
When the wire color is striped, the base color is given first, followed by the stripe color as
shown below:
Example: L/W = Blue with White Stripe I Hope this Can Help People In the future with their installs and add to this.
Edited by joshm35
A really good suggestion, Ian. Just curious, though; do you happen to know which harness would work for the Nissan to ISO bit? I've seen a few floating around, with various years and model specific but cant really find one that pertains to G/V35 skyline but I have found one for the 350z.
Not sure if the 350z one will work, though...
Cool, I have that one on my watch list. Curious, do these cable pass on any of the vehicle information? To clarify that a little, (even I had to re-read that), I've got a Pioneer AVIC-F920BT to throw in the car once I get it in the driveway and the built-in GPS has an input for the speed signal. Does the harness pass on that data or does it need to be tapped from the speedo somehow?
Hopefully I'll be able to play around with it all soon as the car gets delivered to the compliance shop shortly, if it isn't there already =)
No, the wiring harness won't contain any of that, you'll need to pick up speed signal from the ECU or somewhere similar
To find out what wires are what in the factory loom, check the InstallDr PDF...
http://www.installdr.com/Harnesses/Nissan-Wiring.asp
Speed data is sent down the CAN data line, you cannot tap into it for speed without a decoder. There is apparently a 4 wire brown plug taped to the loom above the cig lighter which may have speed pulse output but I have yet to try and find it.
The only reason I can think of as to why a GPS needs an auxillary speed input is to provide some sort of info when going through a long tunnel or in an underground carpark. If that's the case, & because all cars are different, it probably calibrates itself with the speed variable frequency of the speed signal against GPS speed. Then it knows how fast you are going even if it can't see the satellites.
If all that sounds like what it does/needs, then you can use the same speed signal that a cruise control uses to maintain vehicle velocity. There's 2 wire locations you can use. Both are relatively easy to find & one in particular (blue one) is right beside the stereo. They are documented in this thread: http://www.m35stagea.info/forum/viewtopic.php?f=24&t=282
Cheers, Leon.
If all that sounds like what it does/needs, then you can use the same speed signal that a cruise control uses to maintain vehicle velocity. There's 2 wire locations you can use. Both are relatively easy to find & one in particular (blue one) is right beside the stereo. They are documented in this thread: http://www.m35stagea....php?f=24&t=282
Cheers, Leon.
I think that's exactly what the speed signal is used for, Leon, thanks!
Found this after confirming Leon's theory: "In addition to the GPS antenna the navigation takes input signals from the car’s speed sensor and reverse light wires, but these two only aid in sheer accuracy and aren't strictly required."
Again, thanks Leon. I'll have a shot at using the wires described and will send you a PM regarding those Cruise Control kits; they're certainly something I want to throw in there too. =)
Glad I could help. It was just a guess but I couldn't think of any other reason a GPS would need those inputs.
Sorry Dom, I won't be able to help with a cruise control, but if you read the EOI thread there will be info on where else you can get one.
Thats cool, I'll have a poke around the EOI thread and see what's what. =)
I got a sony unit with a aux jack in the front. I connect the tv tuner video to oem tuner. I then ran audio cables under floor from audio jack in tuner to the aux jack in head unit. To listen to tv I just select aux option. Works great. Hope this helps. You just need a red/white audio plug to single headphone jack. So much better than oem headunit.
  • 2 years later...
  • 1 month later...
Hi All,
Just curios, can you keep the original head unit and run an auxiliary input into so that a phone/mp3 player can play through the existing M35 stereo & head unit? My aim is to have a cable with headphone jack coming out somewhere near the centre console, allowing us to play from mp3 player or phone. Anyone have advice or experience with this?
Hi All,
If it doesn't have an aux switch on the front then you can't.
I have the single DIN CY230 cd player which doesn't have any aux.
I'm looking at installing a media player into the tv tuner via rca.
The TV Tuner does have aux in but it's a 6 pin square plug.
I'm trying to source a lead.
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
