hey folks
just been looking at pics on the net of r32 gtr engine bays and first thing i noticed was that my GTR is missing the ABS unit although the brakes still work.
Ive only recently picked this GTR up and had it registered, but still needs some work untill im happy with it.
Is there a reason the ABS unit may of been taken off ? for drifting or somthing ? Or has more then likely the unit just failed so they just ripped the whole ABS unit off ?
its a 1994 r32 gtr.
I did originally wonder why there was only 2 metal brake lines running accross the firewall but didnt take no other notice of it.. now ive relised why theres only 2 there...
the car is only going to be driven on the weekends so idearly i want an ABS unit put back on there, unless they are prone to failing quickly ?
any advice is appreciated
cheers
https://www.sau.com.au/forums/topic/397713-no-abs-unit-on-my-r32-gtr/
yes its a 1994 model - written on the build plate, reg papers.. even nissan fast says its a 1994 model when punching in the VIN
So there would really be no other reason to the removal of the ABS unit unless it fails and the owner cannot be bothered replacing the unit.. ?
is there much work in reinstalling the ABS unit ?
Edited by r32gtrv-spec
After 20 odd years many 32 ABSs are leaking. New ones are $1500. I've not heard of any confirmed cases of successful rebuilds. Since ABS is safety equipment its illegal to remove it.
Re: "If you know how to drive, you shouldn't need ABS". On the street where there are different surfaces and conditions, you wont know where the braking limit is. ABS is good.
it may be illegal to remove the ABS unit although it was never picked up on 2 Roadworthy certificates or when it was complied when it was imported...
Ill look into getting a brand new ABS unit soon - but im going to need all the metal hosing that goes with it
Yeah no-ones likely to ever know about the abs removal. I got my new abs from rhdjapan.com
correct...so the question is...does your car have a rear wiper?
I think it was most likely changed as it was leaking as Adam said
BTW I think it is optimistic at best to suggest no ABS is better for street (or even rally use). Maybe for an experienced driver on a race track, but that is about the only time.
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
