I recently purchased a Wolf3d V4 ecu to use on a rb30det I have just finished building. The ecu was used on a highly modified rb25det and is not suitable for my setup *obviously*, it floods the engine to the point it hydro/petrol locks it and will not start it.
Does anyone have a basemap for rb25det to suit? So the car can moved around/driven carefully to get dyno tuned?
Cheers.
https://www.sau.com.au/forums/topic/397718-wolf3d-v4-rb25det-basemap/
Are you saying that it litterally locks the engine by filling the cylinders? !!
That is not an ECU issue. More likely you have an injector stuck open, probably due to incorrect wiring.
The V400 running a 6 cylinder will have to run 2 injectors on each of the first 3 injector channels, so they run as either a batch or semi-sequential arrangement. No single map will be a plug and play solution for you.
Cam sensor configuration will dictate how it works too.
Upload a copy of your map I can check it out for you.
Yes, full on locks the engine. Starts mint with rb25de ecu.
Yeah thats what I originally thought as well so replaced injectors, new seals and pintle caps, cleaned fuel rail etc. No change.
Would the lack of air temp sensor be the cause? using internal map sensor instead of AFM. Just remembered I don't have one currently connected at the moment since i'm waiting on IC piping to arrive.
Wolf3d map:
http://www.filefactory.com/file/76wx7opfc7o9/
File factory isn't letting me download your map.
If your air temp compensation is turned off, the ecu won't apply any corrections. THis is pretty typical of a lot of wolf ecu's ive seen installed. Its worth sorting out though.
You should be using internal MAP, not the MAF sensor.
The hydraulicing issue is a serious one, and is probably something else. With the ignition off unplug all your injectors. Then turn the ignition to ON, and plug in one injector at a time. If you hear a click on any of the injectors as you plug them in, your wiring has issues. Injectors should remain closed unless the engine is running.
PM me a list of all your modifications, injector sizes and your email address. See if you can sort out that download link too.
  • 1 month later...
  • 5 years later...
    • *that* is a question for chatgpt (or someone that understands maths....but I'd try chatty). Drop them the table and ask for the formula
    • Alright. Exhaust has been looked at, and booked in 'soon'. I'm not 100% convinced it's going to be as good as possible but I'm going to go with it anyway. If I get a reasonable thing that works for 10 years I mean that's twice as long as I've lived with the current one. I have a more pressing issue. I have fixed my MPVI3 (by buying a new one). Excellently, one can wire in analog 0-5v inputs to the ECU itself. I had wideband already via Serial so I also wired it in via the direct input. The idea being I can use the standalone logging without a laptop and have Wideband data in it. The other wire I thought I'd use oil temp. This is where I've gone crazy. HPTuners requires you to implement a formula so you know how much volts = how much temp. This seems relatively simple to me. However I cannot find the scale for this anywhere on the internet, nor decipher how to figure it out without removing the sensor from the car. All I know is that voltage actually goes up as temperature goes down. I am using the actual gauge, so I can see what the temp is. The signal wire has been branched off into the MPVI3. EXAMPLE: 2.68v = 58C 2.7 = 57C 2.74v = 56C 2.8V = 54C 3.06V = 49C 3.18V = 47C 3.37V = 43C I think the gauge is 50-150C. It may be more. It may be less, because I can't find it for the love of f**k. It appears all the information about the gauges I have has been scoured from the internet, but the sender is VDO 320.021 I believe the resistance chart is this How the f**k do I convert this to a voltage? Once I have a voltage... I then have to perform this transform of said voltage to show it in the scanner: https://www.hptuners.com/help/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm @GTSBoy you're probably my only hope here TEST YOUR MIGHT
    • Here’s the updated and installed muse replica nismo ones … very happy with the outcome. Eventhough I painted my whole rear end due to my rich idle lol.
    • Hmm. I had a good look (w/o searching, because I'm not logging in) and couldn't see it either. I distinctly recall the thread, not many weeks ago. It must have been removed or perhaps put into the back section. If it was in Off Topic you should at least have been able to search it up. So if I'm not hallucinating, it is fairly decently removed.
