Selling my XR6 Turbo to help with a house deposit.
- 75xxx km
- 6 speed auto
- Leather interior and factory upgraded steering wheel
- Not an ex fleet or police car.
- Never modified, the only change is a replacement oil feed line to increase turbo longevity
- Being a BF Mk2 the engine has the upgraded internals the same as the typhoon from the factory.
- Well maintained with service history
- Never been in an accident
- Towbar fitted
- Hard to find & great looking colour, I've added more pics but it looks even better in person.
- 12 months rego
Located at Gosford, NSW on the Central Coast only 1 hour north of the Sydney CBD.
A great car that I'm reluctant to let go, if you're looking for a good low km example this is the car for you. Mechanical inspections welcome. Car can be viewed after 7PM weeknights or on weekends.
Price: $20500
Price negotiable but no low ball offers thanks. Not interested in any swaps.
Contact via PM or mobile number available through carsales
Carales link: "http://www.carsales.com.au/private/details/ford-falcon-2006-12401858?sort=default&silo=Stock&cr=0&eapi=2&vertical=Car&find=ent15n|CarRego&__N=1246 1247 1252 1282 " or search ENT15N from the carsales homepage
Plenty more pics in the car sales ad so I'll just put one here.
https://www.sau.com.au/forums/topic/397722-fs-2006-bf-mk2-xr6-turbo-sedan-nsw/
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
