sorry what i mean is it should make more power with your manifold on my car.and that if someone is making just under 350kw with a stock one then your manifold should be able to make more. in theory
will i get a better price if i mention jim lol
No better price I don't think.hah.
I getcha. Yes I can definatelt make much more.power with this manifold.
  • Replies 87
You guys will wanna be careful hanging ext gates on manifolds that have had material taken out.
1. The manifold is now weaker
2. You are adding more weight
The chances it'll crack are now even higher, in standard form they rarely crack but people have certainly taken out too much meat in the past and then had them fail. Making all the stuffing around worthless.
Just something to think about, don't get too crazy with taking material out everywhere you can.
$800 is quite expensive when you can get a proper after market one for $400 more :/
That's why you take it to a pro. Dont want some tard making your manifold into tissue paper.And air temps through manifold are now cooler And has less resistance travelling through. Despite loosing material I would say its prob a little safer, If not the same as stock. As long as too much material isn't taken out.
Regarding external gate that I think is a fair call. Hanging weight off a thinner material may not be a great idea.
Only internally gated bottom mount manifolds I found were 1800. So this was the cheaper option for me. Pretty happy all round!
ported stock manifold $800... 6boost $1200.. i know which one i would go.
If top mount or externally gated. Yep. Anyone got cfm 6boob. Cos my gains are pretty good. Nearly 30rwkw. 100nm torque. Forget the name. How's it flow?
I'm certain there has been at the least one user who did get it professionally done, and it cracked after a little while (not immediate).
Hard to know with every single manifold how much to/not-to take out etc
Yeah top mount all the way, especially for that sort of coin..
Also there's a few welding gates onto manifolds lately, yes it works to sone extent but this is a budget hack mod..those of you with cash to spend on good setups shouldn't even be considering it..
Yeah I'm looking at you Nick ;)
Yeah. Time will tell I guess. Hopefully turns out OK :)
hahahahahha thanks yer i know i was looking for the easy way out but it looks like ill have to 6boost it with a comment like that.or if i could get my hands on a hks low mount one.
looks like im going to have to sell my 2000k old ceramic coated .87 pro s rear housing & dump it never ends ARTZ !!
No limit so far going bottom mount. Manifold could have Been a hiccup, but 50% flow increase is a nice gain. Plus I look stock under the bonnet.
Standard dif haha.
Haha no wonder she is a pig to drive :woot:
Get a decent diff and feel how much straighter she drives and how much more pressure it puts on your tail bone when she starts putting the power down....
Absolute next mod for ya shopping cart mate :thumbsup:
Lol. Read pig as "beast" and yes. Need dif. Like a cusco semi locked number?I get the impression fully locked will drive me bananas.
lHaha i have a 2way id say 1.5 would be better for the street or an R34 diff if $$$ are tight :P
I run a Tomei 2-Way in the 34.. they are really not as bad as you would think, unless your cornering at a decent speed and have to launch the brakes you wont slide around
Yeah? Hmm. I would have though avoid 2way? From the info I'm gathering 1.5 may be the go. What's main dif (pun intended)between 1.5 and 2 way as far as day to day drive ability. What am I gonna feel when doing things like round normal corners or a maccas drive through?
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
