Happy to run it up one day for free, i remmeber we did one or two runs to check it over for Tyson but i thought it was closer to 290, will check tommorrow.
When do you want to do this trent? Where abouts is your new place? Its looking pretty shmick.
  • Replies 87
Spent 6 or so hours cleaning up mine best I could with a die grinder. Took heaps out but hopefully not too much. Bolting a HG SS2 to it. Just waiting for the head which is getting heaps of port/chamber work and cams.
That's similar to my setup, although I'd call the approach mild. Removal of sharp edges, smooth out transitions, etc.
Cast manifold has lots of areas for small improvements around each runner, but the collector area is all about achieving tight packaging. The telltale blue indicates it is clearly the hottest and most stressed part of the manifold, so while there is scope for good improvement in the collector, I stayed reasonably conservative with the amount of metal removed so it won't fatigue and crack.
I'm happy with the overall result
  • 2 months later...
How are the ported manifolds going for you guys?
I've got a stock rb25 exhaust manifold sitting in the shed and a die grinder. Going to give it a crack sometime soon.
Would wrapping the thing in exhaust heat wrap do any good?
I ground the crap out of mine. Port matching plus 1mm oversize each flange compared to the ports. Opened the collector up to gasket size which was quite a but then opened up everything in between I could get to. Then flapper wheeled everything to polish it up. Expecting my turbo back from Stao any day to give it a go. Each port was poorly lined up to the head from factory and could see the carbon marks on each flange
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
