Hey guys,
I have recently bought a 33 gtr.
The background to the car is as follows:
The motor was built last year, there is about 19k on the clock.
It has JE forged pistons, race bearings forged rods and heaps of other stuff (I'll post up specs when I get home and look at the paperwork)
Anyway, the engine had a knocking noise at about 3k rpm and up to about 4.5k. I was told the engine had this before and after the rebuild. It appears to come from the head.
After driving through the hills I was heading p to a corner and upon increasing rpm the engine sort of felt a little tiny bit rougher than normal.. So I decided to stop and check it out. Revved it a little and the noise was the same. Thought I would baby it home because at this point I didn't want to cause damage. Over the next few Kim's the knocking got progressively worse and was starting to appear lower in the rev range until it was happening on idle. I stopped right away and got it trailered home.
I suspect it is bottom end. The noise is not quite as bad on startup. It also doesn't make the noise it you turn the motor over with the starter.
Any ideas? Have other people experienced this? I would suggest the motor would still be under warranty.
https://www.sau.com.au/forums/topic/397832-gtr-engine-stuffed/
Yes I can get a vid of the knock. It's a real sort of metal on metal knock.
I didn't get it professionally inspected. I know I should have now. To be honest I never heard the noise while we were taking it for a test drive. Probably because we just went for a short boost and then I said I'll take it. I only noticed the noise on the way home. Then however the noise was only made between 3-4.5k rpm and just off throttle. Like if you hold it there and where there isn't much load... I.e: on flat road.
Now it does it at idle.. :,(
Unfortunately the owner lied to u. The.noise at 3000rpm is a big end bearing issue, do not drive the car anymore, the engine will have to be pulled out, sump taken off, crank out and inspected, rods inspected, new bearings put in and te clearances checked, depending how long the knock has been there, hopefully the crank and rods are still ok.
U would have finished it off doing a run in the hills, RB series motors have issue's with oil starvation, and hills are the worst for it if the engine isnt setup with baffling, enlarged oil returns, extra oil in the sump etc.
Sorry to be the bearer of bad news
My mate had the same problem after he bought his gtr,
Stated to knock at higher revs only and sounded like it was coming from the head
Slowly started to get worse and knocked at idle like you described
Ended up been number 5 and 6 rod bearings, he was lucky no damage was done to the crank/rods
Goodluck!
Ok so it appears that the consensus is the bottom end.
Thats very annoying considering the motor has only just been rebuilt. (I have the receipt)
It even has a tomei baffle sump in it..
Ohh. Well then ring the engine builder and ask them if they can check it out. How
Many km's have been put on it?
Few possibilities if its a really fresh motor, things like dirty assembly, incorrect clearances, didnt clean out crank and block correctly etc etc.
Or of course driver abuse
I just called the previous owner and he said they seemed a tad dodgy.
I am going to take it to another builder and get their opinion first. Then I'll take the other guys to the cleaners if need be.
Such a poor effort on the part of the builder though. I am very disappointed. Either way the motor is going to have to come put of the car.
Can anyone recommend someone I can take it to?
Where are u located? Actually Gtr engine removal isn't that bad, my mate and I did his in 4 hours and then another 4 hours to strip the engine and clean the work shop, there's a few little tricks but it's not really that bad at all
Scott
Engine rebuilds normally come with 12 months or 20,000kms warranty. You will have to check the receipt for the Terms and Conditions on the engine rebuild. I don't beleive you have any legal recourse with the previous owner. "Buyer beware". Car yards are a different matter, obviously.
If it does fall within the warranty period the engine builder has first right of repairing the issue. You will need to speak with them and if no luck write a factual letter, being polite, but a letter of demand none the less. If that fails to motivate the engine builder/shop to come to the party organise a fair trading (S.A is something like Office of Buisness Consumer OBC or something similar) certified engineer to be on hand when the engine is removed. You will need to engage them to write a report, with pics and root cause of failure. Cost $600 to $1000. Based on the report - it's off to concilliation/arbitration hearing with the Shop.
An award will be made.
If the shop refuses to pay and is a memeber of MTA then MTA will pay you :) and deal with the shop.
The issue with shops paying is that they can ask to pay a small amount on a regular basis and generally the arbitrator will say yes.
No one really wins. Thats the whole point of the arbitration process.
Cheers
$19k is a lot to be stung.
I'm not sure how long you have owend nor how you have treated your GTR since owning it.
But dude, owners know if there car isn't right.
Engine builders - fark me - it's extremely hard to find a good one. Good ones will stand by their work and come to the party to identify the fault.
I do  believe that the motor does fall within the warranty period, what you have stated above seems like a decent avenue for getting some equity back into the situation. The fact that I am a lawyer (by profession) will also help.
I have owned the car for two weeks and have driven it about 5 times. I didnt drive it as much as i would have liked as a have a 7 series BMW to putt around in.
Hey, usually warranty is not transferable, if possible see if you can get the person who had the work done go and bat for you with the engine builder
Good luck!
It isn't transferable, and even if it was small companies will weasel there way out of it and you'll have to take them to court to get anything out of them.
Bite the bullet and take it out and get a reputable workshop to look at it, imo there aren't many and I've heard far more bad stories than good stories with rebuilds, I don't really trust anyone these days though a second hand GTR motor is just as risky as most rebuilds.
    • It can't be some stupidly proprietary video signal coming out of it that only Nissan's can understand. Surely you can just find some generic camera to stuff in there and use hot melt glue/blu-tac/gaffer tape to hold it in place if need be?
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
