Wts Gt3076R + Oem Manifold / Spacer / Dump Pipe
Im selling the below Turbo Kit which is in Used but like NEW condition. Turbo has only done 10,000kms since installed September last year. There is NO shaft play at all.
- The below WILL bolt straight onto a RB25. Studs and gaskets are NOT included. Prefer pickup but if postage is needed it will be at the buyers expense.
Price $2,800.00
What i am selling is;
OEM Manifold / Spacer / GT3076r"Internal Gate"/ Dump pipe to suit 3" / Oil and Water Lines.
- I can also include Silicon hoses and pipeing Turbo side only. *Pipeing was made for AFM*
550HP
* Garrett GT3076R-12 (700382-5012)
* RB Turbine Housing (RB25-GT28) 0.70 A/R
* Hi-Flow of Turbine Housing
* RB Water/ Oil Kit
* Silicon Reducer
* Dump Stud Kit
* Silicon Joiner
* Hose Clamps
* Spacer Plate
* Gasket Kit
* T/E Clamp Kit
* Actuator 16psi
* Actuator Bracket and Rod
If you have any questions please don't hesitate to ask. Thanks.
Yes you probably can. Im selling a straight bolt on setup. Water / oi lines manifold/ dump pipe and piping if wanted. You can't buy that for $1700.00 with the same turbo.
I am chasing $2,800.00 for the setup but that doesn't mean i expect it to sell for that price.
you will get alot of scrutiny at that price, just a kind bit of advice
Sriver, Thanks for the advice. As this is the first time i have actually tried to sell something especially that is pretty much BN... I really don't have an idea on what a good price for this setup would be. As im going Top mount with a GT3582r i don't need anything on the exhaust side that's currently there.
Turbo cost me $2,453.00 from Boostn Imports. Nothing wrong with the turbo just after a high mount with external gate.
Cheers.
So you were trying too sell for 400$ more then what you paid for it lol?
No what i was trying to do and as i stated above was sell it as a complete bolt on sale. Manifold / Spacer / Turbo / Dump pipe / IC Piping / Clamps / silicon hoses. So if someone purchases this they don't have to stuff around to put it on there car. It should take no more then an hour or 2 to put it on without any problems Please read before you post. Remarks like yours with sarcasm are never appreciated. If your not interested then don't post.
550HP
* RB Water/ Oil Kit
* Silicon Reducer
* Dump Stud Kit
* Silicon Joiner
* Hose Clamps
* Spacer Plate
* Gasket Kit
* T/E Clamp Kit
* Actuator 16psi
Is already a kit you can buy brand new for 2400$ from boostn imports, im not being sarcastic just being realistic. Ile give you 1700$ for the lot.
Edited by 51NNA
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 馃檪
    • After drying a few days, time to put her back together
