Wts Gt3076R + Oem Manifold / Spacer / Dump Pipe
Im selling the below Turbo Kit which is in Used but like NEW condition. Turbo has only done 10,000kms since installed September last year. There is NO shaft play at all.
- The below WILL bolt straight onto a RB25. Studs and gaskets are NOT included. Prefer pickup but if postage is needed it will be at the buyers expense.
Price $2,800.00
What i am selling is;
OEM Manifold / Spacer / GT3076r"Internal Gate"/ Dump pipe to suit 3" / Oil and Water Lines.
- I can also include Silicon hoses and pipeing Turbo side only. *Pipeing was made for AFM*
550HP
* Garrett GT3076R-12 (700382-5012)
* RB Turbine Housing (RB25-GT28) 0.70 A/R
* Hi-Flow of Turbine Housing
* RB Water/ Oil Kit
* Silicon Reducer
* Dump Stud Kit
* Silicon Joiner
* Hose Clamps
* Spacer Plate
* Gasket Kit
* T/E Clamp Kit
* Actuator 16psi
* Actuator Bracket and Rod
If you have any questions please don't hesitate to ask. Thanks.
Yes you probably can. Im selling a straight bolt on setup. Water / oi lines manifold/ dump pipe and piping if wanted. You can't buy that for $1700.00 with the same turbo.
I am chasing $2,800.00 for the setup but that doesn't mean i expect it to sell for that price.
you will get alot of scrutiny at that price, just a kind bit of advice
Sriver, Thanks for the advice. As this is the first time i have actually tried to sell something especially that is pretty much BN... I really don't have an idea on what a good price for this setup would be. As im going Top mount with a GT3582r i don't need anything on the exhaust side that's currently there.
Turbo cost me $2,453.00 from Boostn Imports. Nothing wrong with the turbo just after a high mount with external gate.
Cheers.
So you were trying too sell for 400$ more then what you paid for it lol?
No what i was trying to do and as i stated above was sell it as a complete bolt on sale. Manifold / Spacer / Turbo / Dump pipe / IC Piping / Clamps / silicon hoses. So if someone purchases this they don't have to stuff around to put it on there car. It should take no more then an hour or 2 to put it on without any problems Please read before you post. Remarks like yours with sarcasm are never appreciated. If your not interested then don't post.
550HP
* RB Water/ Oil Kit
* Silicon Reducer
* Dump Stud Kit
* Silicon Joiner
* Hose Clamps
* Spacer Plate
* Gasket Kit
* T/E Clamp Kit
* Actuator 16psi
Is already a kit you can buy brand new for 2400$ from boostn imports, im not being sarcastic just being realistic. Ile give you 1700$ for the lot.
Edited by 51NNA
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 2 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
    • Take this with a pinch of salt, it's from someone (me) who got annoyed with turbos entirely. I hated aftermarket lines. If I had the option to use hardlines with whatever turbo I had - I would use them, 10/10, 100% of the time. The only reason people go larger, heat resistent, shielded lines etc is because they have to. And yes they don't last forever. Even if you spend big bucks on all the best heat shielding money can buy, with the best heat resistant, fuel resistant, oil resistant, radiation resistant hose, they get stiff and break down and just don't last the way a metal pipe will.
    • Unfortunately I am quite literally halfway across the globe. So all sources for parts like that are far away for me. What do you mean by that exactly?
