Wts Gt3076R + Oem Manifold / Spacer / Dump Pipe
Im selling the below Turbo Kit which is in Used but like NEW condition. Turbo has only done 10,000kms since installed September last year. There is NO shaft play at all.
- The below WILL bolt straight onto a RB25. Studs and gaskets are NOT included. Prefer pickup but if postage is needed it will be at the buyers expense.
Price $2,800.00
What i am selling is;
OEM Manifold / Spacer / GT3076r"Internal Gate"/ Dump pipe to suit 3" / Oil and Water Lines.
- I can also include Silicon hoses and pipeing Turbo side only. *Pipeing was made for AFM*
550HP
* Garrett GT3076R-12 (700382-5012)
* RB Turbine Housing (RB25-GT28) 0.70 A/R
* Hi-Flow of Turbine Housing
* RB Water/ Oil Kit
* Silicon Reducer
* Dump Stud Kit
* Silicon Joiner
* Hose Clamps
* Spacer Plate
* Gasket Kit
* T/E Clamp Kit
* Actuator 16psi
* Actuator Bracket and Rod
If you have any questions please don't hesitate to ask. Thanks.
Yes you probably can. Im selling a straight bolt on setup. Water / oi lines manifold/ dump pipe and piping if wanted. You can't buy that for $1700.00 with the same turbo.
I am chasing $2,800.00 for the setup but that doesn't mean i expect it to sell for that price.
you will get alot of scrutiny at that price, just a kind bit of advice
Sriver, Thanks for the advice. As this is the first time i have actually tried to sell something especially that is pretty much BN... I really don't have an idea on what a good price for this setup would be. As im going Top mount with a GT3582r i don't need anything on the exhaust side that's currently there.
Turbo cost me $2,453.00 from Boostn Imports. Nothing wrong with the turbo just after a high mount with external gate.
Cheers.
So you were trying too sell for 400$ more then what you paid for it lol?
No what i was trying to do and as i stated above was sell it as a complete bolt on sale. Manifold / Spacer / Turbo / Dump pipe / IC Piping / Clamps / silicon hoses. So if someone purchases this they don't have to stuff around to put it on there car. It should take no more then an hour or 2 to put it on without any problems Please read before you post. Remarks like yours with sarcasm are never appreciated. If your not interested then don't post.
550HP
* RB Water/ Oil Kit
* Silicon Reducer
* Dump Stud Kit
* Silicon Joiner
* Hose Clamps
* Spacer Plate
* Gasket Kit
* T/E Clamp Kit
* Actuator 16psi
Is already a kit you can buy brand new for 2400$ from boostn imports, im not being sarcastic just being realistic. Ile give you 1700$ for the lot.
Edited by 51NNA
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
