OK, so i purchased my R34 GTT just over a year ago,
It came with
Tein Drift Spec Adjustable Coilovers, with black springs.
Great in the corners, shit for every day use, feels like someone is punching me in the kidneys when i go over a bump..
Im wondering if anyone can provide some info on springs availiable for Teins, as the site is very unhelpfull, and google search have not shown what i am after.
Can i simply run softer springs?
Will the struts just be fighting the springs if i do?
Is there a cheap alternative that i have not thought of?
Am i better off selling the Teins and starting fresh with something else?
If so what are these Teins worth?
Any suggestions would be great.
Thanks
https://www.sau.com.au/forums/topic/397889-suspension-to-firm/
Find out what your current spring rate is as a reference to start with. There some spring rate calculators out there if the spring rate sticky is dead. I went from 10/8.5 to 8.2/6.4 and its way better but still too stiff for street. Would be about right for track only (they came out of a race car). I bought the Tein NAs second hand for $700. I think I sold my old, non-height adjustable Teins for around $400.
I have bc on my gtt and I find them a little to stiff tbh I even played with the settings and didnt notice any real difference. On my gtr I have nismo s tunes and there perfect!
Personal preference always plays a big part
I had Nismo S Tune and IMO they were rubbish! Way too hard.
Do this - find out what is actually in there first, and go from there.
Just throwing it out there..........would heavier wheels make for a better ride with firm springs?
Not really. Unsprung weight is always bad. The heavier a wheel is, the harder it is to control. You need more spring to limit how far the heavier wheel can move, but you also need more damper to stopit from yo-yoing around.
Super Drifts are an aggressively valved shock absorber matched to a stiff rated spring. Great for drift/track, no good for a comfy ride.
Sell them and buy some TEIN SuperStreets or a Bilstein PSS coilover kit.
Personal preference always plays a big part I had Nismo S Tune and IMO they were rubbish! Way too hard.
Yeah I guess personal preference does play a big part but really you think there way to hard? Ive never had any one complain that there too hard and they definitely dont have that real stiff bounce when driving around the streets. You can feel them absorbing the bumps, where as the bc will sometimes bounce you of your seat. Curios what are you currently using?
Racepace Tiens, basically the only thing that is "Tien" is the body :)
But it's triple the price of what you guys are talking about here so not overtly relevant.
I just found the rear very tail happy with Nismo S-Tunes in there, seemed to not be very forgiving to the road at all. They weren't too hard of a spring rate either. Think 8kgs
^ this. I've got Tein Superstreets. Aus spec. surprisingly comfortable for a coilover.
prob not the best choice for track work. but excellent for road use IMO. especially when paired with some aftermarket swaybars 24mm/22mm for eg.
Yes, Aus-Spec coilovers for road use work incredibely well and aren't too stiff at all IMO.
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
