Hey S.au need help with my gtr -__-
car runs like a shitbox especially when is warmed up!
car will miss and broad minded personter and wont rev past 2,600 feels like its a tune issue .. not a coilpack miss or spark miss but an electronic part shit itself f**king my shit up
had issues with air flow meter ... when it was warmed up 1 AFM was causing it to stall when hot ... replaced the faulty AFM now just runs shit house but runs -__-
timing has been checked .. throttle position sensor doesnt cause survere symtoms im having .. coolant temp sensor was recently replaced (ecu type)
any1 have ideas on what would cause this ?
any1 know any good import mechanics preferably with scan tester in brisbane southside?
cheers S.au f**k piggs!!!
https://www.sau.com.au/forums/topic/397906-engine-problem-with-rb26-r32-gtr/
car doesnt shake heavily .. although it could possibly be 1 cylinder down =/ or head gasket issue ( hope not though ) dont have comp tester or TK tester
hope its just some sort of sensor fault ... ecu shit itself ? common problem =/ ???
  On 16/04/2012 at 9:29 PM, lilcrash said:
I've got Nissan data scan and I live in Ipswich/work at Richlands if you would like to see if the self diagnostic has anything to say.
diagnostic scanner would be choice !! when are you free ? would be much appreciated!!
  On 16/04/2012 at 7:43 PM, DVS JEZ said:
It still sounds like an AFM issue. Do u have 2 known working ones u can borrow off a mate or sau friend.
Where are u located
Southside brisbane Forestlake
originally had AFM issue .. 1 was causing it to stall .. replaced that 1 and it stopped stalling ... but runs like shit =/
when i change the other AFM with the 'faulty' 1 .. car stalls again *thinks* dam 26s
  • 1 month later...
    • Don't take it as a guarantee. It's all a game of statistics. And on top of that, smooth over a thick layer of "quality of spanner spinning" as a further Gaussian curve of probability of failure. You play games at anything above ~400 HP, and you're using up margins in terms of engineering and luck.
    • Aye, everything is being touched and all the parts that are responsible for the oiling issues are also fixed. (Crank collar, billet prp oil pump, head return to sump, yada yada yada)  Everything used is of reputable brands like greddy, prp etc. My tuner did mention we’d keep the torque on the “lower” side.   glad to read that my engine won’t blow up on me lmao
    • It's a fuel pump. EFI, high pressure, but specs otherwise unknown. A bodge job.
    • 800 engine horsies is fine. Will need all the obvious upgrades. Rods, pistons, oil pump, big sump, sump breathing mods. Build for revs because revs are power with less stress on the bottom end compared to boost. Keep the torque down in the midrange, either by limiting boost or timing.
    • Hiya guys,    i’m currently in the process of getting my rb26 built. everything is being replaced with better/upgraded parts or oem when that’s good enough (which isn’t alot lol). someone earlier mentioned to me that i’ll be screwed cause the iron block can’t take 800hp (to the engine, not wheels) which is what it’s being built for.  what do you guys think about this, am I cooked or na? The guy building the engine will also do the mapping as he is “the guru of old nissan engines” here in Belgium. I know the mapping makes a huge deal so i’m not concerned about that.    I honestly he’s talking shit cause he’s that kinda guy but a second opinion never hurt anyone! cheers in advance! 🫶🏻
