hey S.au
obviously not as simple as low range and high
setup : 15inch sub running off seperate amp .. amp is set too Low Pass Filter
2x 6x9 and tweeters in seperate box in boot with seperate amp ... amp is set too high pass filter
4 fairly average pioneed speakers inside car
pioneer headunit has high pass filter option and sound retriever .. cant tell much difference with HPF on headunit but sound retreiver on option 2(bass) is clearer
What HERTS should sub be set on ?? 60Herts ?? low range ??
what about mid range and other settings ?? theres millions or HERTS SETTINGS LOL
reset battery so my settings are goneeeeskiiieeee f**k THE POPO!!
  • 3 months later...
what is so wrong about it? slight overlap is fine, I doubt 6.5" car speaker have a flat response all the way down to 60Hz anyways, they're not home speakers.
to add, front speakers are infinite baffle, not even sealed or ported, so if my advise if "wrong" as you say, what would you recommend?
Edited by johnnilicte
80hz is fine on sub
Disconnecting what sounds like pawn shop speakers in the rear is right Too dodgy sounding to know how its installed
4 average speakers in front at 60hz in infinite baffle will be the death of them
Infinite baffle is the worse control of the cone there is except a way out of tune box
Most front speakers cant play down to 60hz without excess cone excursion because of the above reason , good home speakers in a sealed box you could go low but even them 60 is too low unless your crossover is 24db rolloff even then its risky
120hz -200hz would be more like it depending on the rolloff, power applied , specs on speakers etc
120hz -150hz at 6db rolloff is fine for most quality 6.5 in if no bass boost is used on amp or deck and power is clean
But like i say 60 hz on 6.5 " is going to be a short life before voicecoil death
All of this is assuming active crossover not passive and active mixed together which throws in phase delay and a few other items
I did say 60hz to 80hz, I ran my Focals at 60hz to get good solid midbass at the front, I am still sure the voice coils are perfectly fine if I were to put a multimeter across them.
You prob did run your focals at 60 -80 on the amp and then ran them thru the passive crossover !!
Which filtered out the bass overriding the amp Electronic crossover at certain freq ranges
And creating a 18-24db crossover in the process
The natural rolloff is higher then 60hz in most all cases for 6.5 "MID "range
60hz is bass to subbass region not midrange freq
Focals arent magic they will die just like any other speaker , dont forget this guy has low range speakers and possibly thin mount coax as well recipe for burned coils
Without getting into advanced acoustic / electronic engineering and why you dont xover at 60hz on a 6.5 mid range any brand !! Even 6.5 WOOFERS can struggle at 60hz unless designed for free air application or custom box made for speaker resonance Q
The overlap with a 15 " would sound horrible
Lots of peaks and valley in response curve With big holes in sound
    • For something like this, I'd skip just going for the cheapest, I'd find the place with the best experiences people have had, especially for restoration work. Like everything, there is upholsterers, and then there is upholsterers. Some really great upholsterers for automotive restos won't even appear to have an online presence.   My guide would be find some of the old school classic cars that have been fully restored and are immaculate, and ask the people who own them who did the work on their seats
    • Might be tricky matching the seat trim material  If your got the funds you "may" want to get the rear re-trimed as well to match the front
    • How much is it to re-uploster?  Well that's a "how longs a piece of string?" question !  And I answer thusly: "twice half its length! " . . . . . .  Seriously you'll have to chase multiple quotes for that one from different uphlostrerereres !  Ask around, in your area and on the forums, chase reviews and most of all see the finished product in person cause photoshop is a wonderful thing !
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
