Hi everyone, im looking to sell my R34 GTT.
Pictures will be up in the next few days.
1998 r34 GTT 2door
Nismo cluster.
Nismo triple guages.
Nismo gear knob.
Nismo front and side clear indicators.
Drift blade drivers seat on adjustable r34 rail, both ADR approved. not a cut and shut rail.
work xt7 wheels bronze, 18 x 9.5 +20 all round.
235 tires all round.
blue work wheel nuts.
heavy duty button clutch (not sure of brand, was in car when i bought it)
New Blitz coilovers.
Adjustable front camber arms.
HICAS lock bar.
Adjustable heavy duty whiteline sway bar front and rear.
Blitz return flow fmic
Apexi highflow panel filter
GCG high flow turbo
hks 15psi actuator
hks cam gears
splitfire coilpacks
highflowed injectors
bosch 040 fuel pump
3" turbo back exhaust
catco 3" high flow cat converter
reinhard 3" catback with 3.5" twin tips.
Power FC ecu with hand controller (power fc is currently housed in a standard ecu case, i have the standard power fc ecu case as well)
tuned by status tuning.
Mongoose alarm, immobilizer, keyless central locking, vibration sensor when armed.
Alpine CDA-9887 headunit
hertz 6.5" front splits
hertz 6.5" rears
6 channel audison amplifier
12" P.audio subwoofer.
12month rego, and RWC.
I've owned the car for a little over 2 years. i've used the car as a daily driver everyday for those 2 years, it has not once had an issue.
Always garaged at my house when home.
$24,500 ONO
SE Melb suburbs.
I think that is all, any questions dont hesitate to ask, PM me if you want to come and see it and ill send you my mobile number.
Edited by lach88
https://www.sau.com.au/forums/topic/397911-1998-r34-gtt-2-door/
Sorry, been stupid busy.
KM's: 60,000 KM (I'm not sure on the exact KM's of the car, as it has a Nismo dash in it. The dash was in it when i bought the car, and was in it when the previous owner bought the car.)
Colour: White
Also forgot to mention it also has, Z32 AFM.
post-69357-0-19721600-1335696155_thumb.jpg post-69357-0-38748200-1335696160_thumb.jpg post-69357-0-73802900-1335696164_thumb.jpg post-69357-0-79787100-1335696167_thumb.jpg post-69357-0-10681900-1335696171_thumb.jpg
post-69357-0-52697800-1335696173_thumb.jpg post-69357-0-32063300-1335696176_thumb.jpg post-69357-0-69579700-1335696178_thumb.jpg post-69357-0-74866100-1335696180_thumb.jpg post-69357-0-99826000-1335696222_thumb.jpg
post-69357-0-04740800-1335696227_thumb.jpg post-69357-0-88400600-1335696229_thumb.jpg post-69357-0-46968800-1335696234_thumb.jpg post-69357-0-68365300-1335696236_thumb.jpg
    • Sell it and buy something newer? 😛
    • Better then PooPooG... or is it PeePeeG?
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
