Thermo's rob power from the engine too, they are less efficient than the engine fan and suck a heap of current from the alternator whenever they are on.
If you set them at a high enough temperature so they barely come on you may be better off, that's my plan. One small thermo and one large one set at different temps may help too.
That's how the are supposed to be set up. But very few actually set them up this way. Many set them so they are permanently on, which totally defeats the purpose - all that does is shift the load on the engine from the fan to the alternator.
The problem I had when I tried it (32 GTS4), was getting air to flow through the radiator while the car was moving. I could only JUST get airflow, and the slightest uphill in the road coud induce the fan to activate.
For the few kW gained by removing the load of the fan, it is not worth cooking an engine.
Well those cars were designed by the manufacturer to use thermos as standard.
A working clutch fan such as the nissans will only draw engine power when at idle or just above, as they are supposed to taper off/decouple as RPM increases.
As they wear out they tend to stay engaged longer and start to sound like an EA falcooon.
When they wear out they stop working i.e you can hold the fan while revving the engine when hot, the viscosity in the gel changes and with the correct type of battery the thermo wont put strain on the alt.
Edited by 51NNA
I beg to differ, it dont matter if your running an n70z or a ride on mower battery if your fan draws 30 amps your alternator needs to make 30 amps, it does however stop the alternator spiking as such.. Unless thats what you meant?
So all the WRX's and many other cars that come from the factory with a thermo fan are going too cook there engines? lol...
You ever driven a Falcon? lol
A clutch fan on an E/W mounted engine wouldnt do much cooling now would it?
Yes, i didnt mean the battery will stop the current draw, but with the correct battery the load would be reduced on the alt, unless the thermos constantly on.
...were did i say "put a clutch fan on a wrx" All im saying is MOST cars come with thermos with no cooling issues and yes ive driven a falcon and worked on 100s, whats that got to do with anything?
On this topic, is there anywhere to but new clutch and fan for rb25? nissan want 750 for it and im not spending that much ill go second hand first, my plastic fan has cracks and the clutch holds the fan on permanently and certainly makes some noise at 8000 revs :-/
Garage 7 sell both the fans and the hubs at a much more reasonable price then that
www.garage7.com.au
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
